Looks like the suggested bridge rectifier in terms of shape and size. Strange thing - those are typically used in power supplies to convert AC input to DC output voltage when followed by a capacitor(s) on the output. I'm not sure where AC would come into play on your vehicle in order to be used as the input supply.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Author of "101 Projects"
I should just restore a VW Bug or a Ford Mustang, or something easy and straightforward one of these days instead of mucking around with Probe 16s, a Daimler Ferret tank, the Fire truck (only 13 made - I still don't have a manual on how the pump works), or the solar car. Heck, working on all of this stuff with no documentation makes working on the Ferrari 360 seem really easy! Just open the manual on the computer, and say "oh, so that's how you get that transmission heat exchanger out". Quote of the day: "I wish I had one of my own books for each of these cars!" -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
-Wayne
Hell Belcho
Honestly, I'd throw a Delco alternator in that thing with a Painless Wiring kit.
Saved by the buoyancy of citrus. |
It looks like the headlight motor runs a cable drive. I've seen this on early 50s Lincolns and American cars used on convertible tops and power seat mechanisms. The relays and controls used to drive these types of motors were quite unique. The problem is that these motors are typically two wire and requires a complete reversal of polarity to make them operate in the opposite direction. One of the old cars that I restored, I replaced the old 50s 6v relays with 4 modern relays using the NO and NC terminals on the relay to complete the reverse polarity task. The other thing that is typically missing from those old controls are how to stop the motor from running when it gets to the end of the travel. In modern cars, when the power window motor gets to the bottom, it opens a thermal fuse to stop. In these older motors and controls, when the motor stalls at the end of the travel, the current goes up which can be used to open a self reseting circuit breaker to stop it. Once you get the system working, you can test with and without the block or individual terminals connected to reverse engineer the design.
I would connect with a good electrical supply house like Waytek, Terminal Supply Inc, American Autowire and use as many modern connectors, fuse panels, relays, and terminals as possible to make a robust wiring system. Working with old cars, you need to touch or inspect every inch of every wire because a rodent, a chafe, degraded tape, etc might be the path to a car fire. With a wood and fiberglass car, that's a lot of materials that like to burn, melt, and combust. Even replace every fuse because old fuses can sometimes not blow when asked. I'm also a big proponent of modernizing the electrical systems. There are a lot of solutions out there with wiring coverings, loom, tape materials, and fabricated covers to nearly hide the entire wiring system and the modernization. The time spent going through everything in detail pays off so much at the back end with reliability and piece of mind. It doesn't look like there is much originality to save there except wire lengths and routing. Otherwise this is a really neat project and a great time capsule. I hope to follow along. Thanks for sharing online. |
Thanks elliotgofast, some good suggestions there. The headlamp motor works okay for now, and you're right, the motor has a total of four wires going to it, which I haven't seen before. I do not know what happens when it reaches its end of travel - it does work okay, maybe this diode bridge has something to do with limiting the current spikes. Here's a photo of the motor:
![]() I've got enough issues to resolve with this car, I'm not going to start "fixing" stuff that isn't necessarily broken at this time. I.E. the stuff that is working, I'm going to literally check it off the list / spreadsheet and move on. I did clean up the diode bridge, but it didn't reveal anything additional, except "Made in Haiti", which is odd: ![]() ![]() ![]() I ordered all the new wire for the harness, it should be here within a week. In the meantime, it's on to working on the brakes (which need everything too)... -Wayne
Random Probe 16 photo I found cool. It really puts it into perspective how ground-breaking and cool this design was, when compared to nearly everything else on the road at the time:
![]() -Wayne
Hi Wayne,
Very cool and fun project. What was the car designed to be? Was it supposed to be a performance or sports car or were they just going for a cool looking car? Rutager
Rutager West 1977 911S Targa Chocolate Brown |
Well now that it's clean I can see 'AC' on one corner, '-' on another. You will find '+' opposite the '-', and another 'AC' opposite the 'AC' on the picture.
This is a bridge rectifier, I am going to guess the wires go back to a rudimentary alternator.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
![]() Looks like this, to me.
I think you're onto something there. So, the alternator on this thing doesn't have a built-in rectifier?
Based on what I've seen from the car so far, I am guessing not. I can't think of another reason for a rectifier.
Well, the alternator does have a voltage regulator and such. I think this has something to do with the headlamp motor having four wires to it - presumably for the field coil winding and the armature winding. It's been about 30 years since I've studied this stuff, so I don't quite remember. A three minute Google search didn't reveal anything useful either. I have a lot of other things to worry about, so I will just plug it back in as-is (since it works), and leave it alone. Unless someone else here knows and wishes to explain...
-Wayne
Coolest new device I have seen in a while! - Classic Blaupunkt Bluetooth Converter...
Okay, so having sold Pelican about three years ago, I've been mucking around with real estate and restoring other cars (working on the 1969 M-505 Adams Brothers Probe 16). But I came across something the other day, that I haven't seen before.
So, on my 1972 911E, I have the standard period-correct Blaupunkt Frankfurt radio installed, and about 15 years ago, I bought a plug adapter that allows me to plug the radio into a standard 3.5 headphone jack like the ones that used to be on the old iPods. That worked great for many years, the sound automatically plays through the old Blaupunkt radio into the standard speakers, and maintains 100% the correct vintage radio. Fast forward to 2020, and I have the Probe 16 we're restoring which basically has the same radio. Check out this thread here for more info: http://forums.pelicanparts.com/off-topic-discussions/1074841-adams-m-505-probe-16-restoration-project.html Here's the radio: ![]() ![]() So, this radio has a plug on the back (very forward thinking for Blaupunkt) that has a cross-over switch (ability to automatically turn off the radio and use an external source), and power as well. Here's the plug on the back: ![]() So, this is what I bought: Quote:
Plugged it in, and it works perfectly. Red Hot Chilli Peppers streaming from my iPhone to my 1970 Blaupunkt Frankfurt radio in the 1969 Probe 16! The sound is of course, from 1970, but actually, these old radios are not that bad! I'm going to recommend that Pelican carry this product, it's pretty good. Literally a five-minute installation! -Wayne
Check this out, I've never seen one of these before on a normally aspirated car - Vacuum gauge. The Smith's gauge guy who does repair said these are fairly uncommon / rare. There is a hose connected to the back of the gauge that runs all the way to the intake manifold in the engine. The hose was clamped off with some small clamp - I'm not sure why. I assumed it was because the gauge was broken, or the hose had a break and was leaking. So, I decided to test it...
Here's the cool gauge: ![]() Here's where it connects to intake manifold: ![]() Here's how you test it - suck on it, look at the gauge, stick your tongue on the end and hold it for a minute or so to see if the gauge goes down (signalling a leak in the system). No leaks! I'm not sure why this was clamped off (maybe I will discover the reason in the future). ![]() -Wayne
Dad's '64 Travelall had a really cool looking AirGuide vacuum gauge and tach on the steering column. They are fun to watch when you're hypermiling.
Looked just like the one linked below.
Scott '78 SC mit Sportomatic - Sold Last edited by Scott Douglas; 11-21-2020 at 01:40 PM.. |
Scott '78 SC mit Sportomatic - Sold |
Those vacuum gauges are still available if yours is NFG.
https://www.caigauge.com/blog/new-smiths-vacuum-gauge-launched-by-cai https://www.demon-tweeks.com/uk/smiths-classic-electrical-vacuum-gauge-smivg1302-03cb/
max |
-Wayne
