Did you get the memo?
Well by that measure every system on every car ever made can be considered problematic.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
I used to wince when I operated the top and all of the popping and banging started. If you've never sat in one and operated the top, your first time it will get your attention. |
Have always loved this feature on all of my W124s
Tru6 Restoration & Design |
I always liked the looks of the W124. One of Bruno Sacco’s finest designs...
I liked that color when they came out with it, too. |
Gon fix it with me hammer
well go ahead and change the headlight unit on that modern Merc . Have fun with it cause the benefit of that fancy hood won't help you do that job, at all.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Maybe a coincidence but the transmission on my 90k D2 S8 failed about 1,000 miles after I changed the transmission fluid and filter. Pretty sure it had never been changed.
Yeah, that is what concerns me. What exactly failed inside your transmission?
I don’t remember exactly it’s been a few years. I seem to recall a fluid pump and failure related to the throttle body.
Valve body?
I loved my A8, but what sent it to the donation yard was, believe it or not, a starter. Was like a 1500 job, on top of control arms (unrelated) and a bunch of sensors that lit the dash up but meant nothing. It was a great car until 180k, and then it imploded all at once.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
I think the W124 is a timeless design. I wish I had bought a 500E when they could be had for under $20k.
You and me both. I’d love to have a 92 model. I’m a bigger fan of the pre-face lift cars, I think.
I’ve been researching the failure points on these transmissions and I’ve got a question for you. If you can remember back that far, can you list the symptoms you had when you first noticed a problem with the transmission? Bonus points if you can be specific as to which gears, transmission hot or transmission cold, that sort of thing.
Flare and then bang into gear, particularly bad from a start. The worst was starting on an incline where the car might roll backwards slightly, when I applied throttle it would slip and then bang into gear. It also did that on a stop on an incline. It also would flare shifts but that was intermittent. I believe it was worse when hot. In tiptronic mode it was far better behaved, far worse when driving in automatic.
Bland
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Mercedes makes it easy when doing a motor swap! this is my 84' 280CE that I pulled the seized M110 motor and swapped in a turbo diesel OM617a in to.
Von http://vonsmog.com 73' 911T Coupe, 76' 911S Targa 73'& 80' Mercedes Unimog DoKa 59' Austin Healey 100-6 |
