Electric water heater issue
I have a 2009 (40 gallon) GE water heater that is not heating the water.
I replaced both upper and lower elements and thermostats and still no hot water. The elements I removed looked OK as did the thermostats, although I didn't bench test them. I have water coming out my hot water side of the faucet but it's not even warm. The output pipe on top of the water heater isn't either. I do have power to both upper and lower elements. This is a head scratcher for me at this point. I'm not opposed to getting a new water heater but would feel better know why my old one is not working first. Appreciate any suggestions/input. The elements were both the same rating as my heater 240v - 4500w. They and the thermostats came in a kit by Everbilt.
Old dog....new tricks..... Last edited by Baz; 10-21-2020 at 07:31 PM.. |
How have you determined that you have power to the heating elements?
Yes....120v to each side. Voltmeter with one lead on a terminal and the other on the water heater body to ground.
Old dog....new tricks..... |
Past my scheduled bedtime, but I would want more details. See you in the AM.
If I got 10 years out of this one, maybe it's time. I usually get an el cheapo from HD, which is what this one was, I'm sure.
Looks like another el cheapo is only $329, so I may go that route anyway. These things rust inside don't they? Maybe that's the problem. Performance 40 Gal. Medium 6 Year 4500/4500-Watt Elements Electric Tank Water Heater
FWIW, I verified 120v on each leg of the breaker and the same thing on the wires going to the thermostat and the element so there's 240v total, so that part should be OK.
The water heater has been working just fine - but a few weeks ago it wasn't heating the water that good so I pressed the trip button on the top thermostat and it was back to normal. That was probably 3 weeks ago. That's why I went ahead with the element swap tonight - thinking one of them may have been shorting. But like I said, both didn't look too bad when I removed them. At this point getting a new WH seems to be the way to go, considering how old this one is. My water closet sits in the middle of my home so don't like the idea of any leak issues trying to eek a few more months/years out of it.
Voltage don't mean much. Invest in an inexpensive amp-clamp, then clamp a wire on a element, any amps when you think it should be on ?? No amps = no heat.
Still Doin Time
^^^^^^^^^^^^this
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Evil Genius
Life is a big ocean to swim in. Wag more, bark less.
Cars & Coffee Killer
I replaced my electric hot water heater back in March with natural gas. Best decision I've ever made. Saves me about $100 a month in electricity.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Thanks again for the input!
I got up early the next morning and decided to double check the electric panel and not sure if this was the problem but I flipped the double breaker back on and off again and this time pushed hard on it while the off position - before flipping back over to on. After a short period of time my water began heating up again and it's been working ever since. Funny that the forum went down but things still worked out on my end - this time.
Evil Genius
pour hot water on the circuit breaker........it'll help make mo' heat !!!
let us know how that turns out..........
UnRegistered User
Dip tube broken?
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Platinum Member
https://www.redbudinspections.com/dangers-of-stab-lok-circuit-breakers/
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I shined my penlight into the tank while changing the elements and it looked very rusty and not all in one piece so I would say yes. Time for a new heater for sure.
You have a good memory!
UnRegistered User
Dip tubes are replaceable.
I did one on my old tank and ended up replacing the tank afterwards anyway. Can't remember why...
Based on this YT vid I just watched, I don't think that's my problem anyway. And whatever I thought I saw - it wasn't the dip tube apparently. I have some corrosion on the outside at the bottom so feel I should go ahead and just get a new one. For $329 (+ sales tax) I think it's a no-brainer, ya know?
Hot water doesn't need to be heated :^) |
