I have no idea how that furnace is sensing the static pressure, but when designing/selecting a fan for high altitudes, a correction factor is applied to the static pressure. So, maybe there’s some thing there.
Here’s a brief explanation of how you correct static pressure for temperature and altitude: https://www.tcf.com/wp-content/uploads/2018/06/Temperature-Altitude-Effects-on-Fans-FE-1600.pdf |
Brew Master
Make sure to bump this thread when the tech looks the system over. I'd be curious to know what they find. I have to stick with the duct system being hosed since the furnace will work without the blower door on. I wonder if the drop duct that comes from the crawl back at the back of the furnace has that same insulation it in that the brilliant piece of duct fabrication pictured in post #62 has.
Only thing I think the altitude will affect is the size of the propane orifices used to convert the furnace. But I'm a lowlander so I can't say for sure.
Nick |
Altitude definitely has an affect on the furnace manifold pressure adjustment.
It’s worth checking, just to make sure that whoever installed the stupid thing the first time did it right. Given what that return ducting looks like, I would assume they didn’t do everything correctly. |
Another thing to check for Wayne is make sure that flex duct is not collapsed on the inside
Somewhere. Sometimes when it gets old it can separate on the inside and collapse but because of the insulated jacket you may not notice it. Also with all of the caked on dust showing I would suspect the a/c coil is plugged which Would cause this and also the outdoor condensing unit to freeze up. |
@ frosty2; Wayne says there is no A/C in this system, so don't jump to conclusions. He has stated the the one giving him trouble is one of two separate systems.
Author of "101 Projects"
Dunno - I thought for sure that cutting the intake hose and disconnecting it (getting it away from that kink from the wooden beam) would magically fix the problem, but it still complained about the motor speed in "test mode" and also while running (although it seemed to complain less after I shortened the hose - which makes sense - if the motor is getting older and more tired then "helping" it a bit by shortening the hose would make sense). -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Brew Master
I don't think it's a matter of he motor getting tired. If anything it's an issue within the ECM that senses the system static pressure and adjusts the speed accordingly. I just think your duct sizing, on both supply and return, is so out of whack that the system can't compensate. This is why I've asked for the number of supply registers and corresponding sizes. I'd be interested in knowing what size the main trunk is that feeds the supply registers as well. So much goes into proper duct sizing and from the looks of things, the original installer had no clue what they were doing.
Nick |
I don't have the number and sizing of the registers, sorry...
-Wayne
Brew Master
No worries. The tech you have going to look at the system will, or should, figure that out. Before the tech starts throwing parts at it, I'd make sure to ask them to assess the duct system. It shouldn't take long for them to look the system over and determine whether or not it is sized properly using the correct static pressure for sizing. There are a lot of techs who don't understand how this system works. I'm honestly not sure what the furnace is capable of overcoming as far as static pressure is concerned. When I did a retrofit with this type of system I'd assess the ductwork, determine if it was adequate and then either install the furnace or tell the homeowner that new ductwork would be necessary in order for me to install this furnace.
Nick |
Look up HVAC Manual J. There are online calculators.
Early on in this thread, someone asked me why I was going through all of this myself, and why I wouldn't just "pay an expert" to come and look at it. Well, $150 later, this is all I get. I'm starting to feel like grandpa Simpson, complaining about everything in this world, but it truly is sad when a) the quality of work is terrible, and b) I can almost predict it like the sun rising. This house is located in a relatively small town, so it's even worse. One thing is consistent - I am *continually* and constantly disappointed by nearly everything these days. For those that know me very well, this theme was part of the decision to sell the company in the first place. You guys have been great though - that is why I asked here in the first place! -Wayne
Hard to find good help, try building a house.
Test the duct pressures, that should tell part of the story. I am thinking the ducts were designed for an older 100k btu system or possibly 80k btu.
87 930, Last edited by 908/930; 01-09-2021 at 03:39 PM.. |
NO THANKS! I like my houses "pre-assembed".
-Wayne
UnRegistered User
6K? Holy crap!
I could see that price if they were to straighten out the supply and return plenums. Point of reference. I had a 16 year old Trane high efficiency two stage nat gas furnace in the house and it started to get a little glitchy. I could hear the difference in the startup of the furnace and would race down to the basement and try to find what was causing the failure. Can't remember what the diagnostic on the flashing LED. After having my meter and tools parked beside the furnace for about two years I concluded it was a motherboard glitch. NLA and the factory retrofit was almost $700 my cost and I had to re-wire the furnace and change out the induced draft fan and no warranty on electrical parts. Went to one of the wholesalers we deal with and picked up a new York two stage variable blower for cost and had a friend pull permit for the install. Done. Fantastic furnace too BTW. Highly recommended.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Brew Master
That's just crazy Wayne. Crazy and inexcusable.
Oh! and this post will cost ya $300. I'll PM ya my PayPal
Nick Last edited by cabmandone; 01-09-2021 at 06:08 PM.. |
-Wayne
Unregistered
I haven't asked a dumb question in hours so here goes:
Have you checked for proper rotation? |
-Wayne
Brew Master
My advice is to get someone who knows what the hell they're doing to come in and assess the system. It sounds like the guy did nothing beyond what you've already done. In hindsight, you probably should have told the company you hired what steps you've already taken (if you didn't)
I'd call the company you used and see if they'll come out and do a duct assessment. Tell them you're considering a new furnace but want to make sure the duct system is adequate. Tell them the tech made no mention of the duct system and that you'd like to have it evaluated and a quote for a complete system provided. The new system quote shouldn't cost you anything.
Nick |
Platinum Member
Nick, why throw good money at an old unit?
I'd shop around for a replacement. I pay around $6k to swap a gas furnace along with new AC & coil. I should think a furnace be about half that.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
