-   -   HVAC Blower help (http://forums.pelicanparts.com/showthread.php?t=1084950)
mattdavis11 02-01-2021 04:57 PM
HVAC Blower help
It's a Rheem.
http://forums.pelicanparts.com/uploa...1612227264.jpg
Can I get the blower motor out without having to remove the coil?
Many thanks!
mattdavis11 02-01-2021 05:04 PM
Another pic.
http://forums.pelicanparts.com/uploa...1612227816.jpg
dad911 02-01-2021 05:39 PM
Directions here, installation instruction PDF: https://www.gemaire.com/rheem-rhal-fr30pjb05a417-2-1-2-ton-front-return-air-handler-up-to-14-5-seer-psc-motor-5-kw-heat-breaker-float-switch-rhalfr30pjb05a417
Says to loosen the screws and tilt down the coil. Never seen that before, blower usually more accessible.
mattdavis11 02-01-2021 06:12 PM
The suction line doesn't seem to have much to give, discharge might let it drop far enough. The motor is banded, which I might possibly remove with the assembly cockeyed.
I have the coil very well protected. Any suggestions are very welcomed.
Thanks!
nota 02-02-2021 09:03 AM
did you check the capacitor many times they fail before the motor goes bad
the little can with wires sitting outside the squirrel cage ?
red-beard 02-02-2021 09:32 AM
That should be under Warranty
dad911 02-02-2021 10:00 AM
Yes, let's back up.
Why are you removing blower motor?
I'd probably cut an access in the side (if it's out of warranty) before risking a re-charge of the system.
nota 02-02-2021 10:11 AM
Originally Posted by dad911 (Post 11208177)
Yes, let's back up.
fan motor if the problem should be 1/2 or so the size of the squirrel cage fan
worst case may need a bit of moving bits but never seen a unit that required the evap
to be moved just the fan detached from the shaft and bolts to free the motor not the whole motor fan and outside casing as a unit as the motor alone is far smaller
mattdavis11 02-03-2021 09:05 PM
It would not be under under warranty because the installer had a great idea which caught the blower motor on fire! Family. That isn't much of a concern, he bought a new one, I get to put it in. When he left after Christmas he thought the coil had to come out.
It doesn't. The manufacturer is spot on, but my unit mounts in a closet and the only way to remove the blower assembly is take the unit all the way out, unless I destroy the house. No access to the side screws in step 8. Tight corner closet, might as well renovate the bathroom too!;)
Step 9 is a no go because of step 8. The motor is out, had to remove the band around the motor, disassemble, and it barely squeezed out past the liquid and vapor lines.
Now I have to put it all back in, including cutting the shaft on the new motor. It's a bit long to fit.
Thanks!
