Just thinking out loud
mattdavis11's Avatar
HVAC Blower help
It's a Rheem.
Can I get the blower motor out without having to remove the coil?
Many thanks!
91 FJ80
84 Ram Charger (now gone)
Old 02-01-2021, 04:57 PM
Another pic.
91 FJ80
Old 02-01-2021, 05:04 PM
Platinum Member
dad911's Avatar
Directions here, installation instruction PDF: https://www.gemaire.com/rheem-rhal-fr30pjb05a417-2-1-2-ton-front-return-air-handler-up-to-14-5-seer-psc-motor-5-kw-heat-breaker-float-switch-rhalfr30pjb05a417
Says to loosen the screws and tilt down the coil. Never seen that before, blower usually more accessible.
Old 02-01-2021, 05:39 PM
The suction line doesn't seem to have much to give, discharge might let it drop far enough. The motor is banded, which I might possibly remove with the assembly cockeyed.
I have the coil very well protected. Any suggestions are very welcomed.
Thanks!
91 FJ80
Old 02-01-2021, 06:12 PM
Banned
did you check the capacitor many times they fail before the motor goes bad
the little can with wires sitting outside the squirrel cage ?
Old 02-02-2021, 09:03 AM
canna change law physics
red-beard's Avatar
That should be under Warranty
James
Red-beard for President, 2020
Old 02-02-2021, 09:32 AM
Platinum Member
dad911's Avatar
Yes, let's back up.
Why are you removing blower motor?
I'd probably cut an access in the side (if it's out of warranty) before risking a re-charge of the system.
Old 02-02-2021, 10:00 AM
Banned
Originally Posted by dad911 View Post
Yes, let's back up.
fan motor if the problem should be 1/2 or so the size of the squirrel cage fan
worst case may need a bit of moving bits but never seen a unit that required the evap
to be moved just the fan detached from the shaft and bolts to free the motor not the whole motor fan and outside casing as a unit as the motor alone is far smaller
Old 02-02-2021, 10:11 AM
It would not be under under warranty because the installer had a great idea which caught the blower motor on fire! Family. That isn't much of a concern, he bought a new one, I get to put it in. When he left after Christmas he thought the coil had to come out.
It doesn't. The manufacturer is spot on, but my unit mounts in a closet and the only way to remove the blower assembly is take the unit all the way out, unless I destroy the house. No access to the side screws in step 8. Tight corner closet, might as well renovate the bathroom too!
Step 9 is a no go because of step 8. The motor is out, had to remove the band around the motor, disassemble, and it barely squeezed out past the liquid and vapor lines.
Now I have to put it all back in, including cutting the shaft on the new motor. It's a bit long to fit.
Thanks!
91 FJ80
Old 02-03-2021, 09:05 PM
