You do not have permissi
(That is your trailer empty weight.) -Then go online and/or somehow obtain the weight of the hauled vehicle. -Add the two together and compare to OEM trailer max specs. I once drove a loaded Ford van across the country filled to the ceiling and at 150% GVW. Check tires and grease the bearings. Drive 60 and keep plenty of space in front. You will do fine forever.
Meanwhile other things are still happening. Last edited by john70t; 03-08-2021 at 09:22 PM.. |
