You do not have permissi
john70t's Avatar
Rake it smooth and put down some big cardboard.
Even though there is an airspace, might even consider some plastic to keep ground moisture from traveling upwards.
Old 05-06-2021, 03:31 PM
I'm wondering what, if anything, I could or should (or shouldn't) do to insulate the bottom of the house.
Old 05-06-2021, 04:02 PM
Zeke's Avatar
That’s what I was saying. No way that meets code.
Unless the red one on the left is a wet vent. It will work and meet code since there is a clean out in line with the waste line. Would it have been better with an "L"? Sure.
Old 05-06-2021, 04:11 PM
The one on the left is waste/drain from bathroom sink, shower, tub, and toilet.
Old 05-06-2021, 04:25 PM
Home of the Whopper
The 90 on the left is fine, but not the Wye it discharges into.
Replace 90 with 45 and replace Wye with long sweep Wye.
Then replace right Wye with long sweep Wye.
Not difficult but still.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-07-2021, 04:16 AM
Are those 6" pipes? In a house?
Old 05-07-2021, 09:50 AM
No real idea how big they are. They probably aren't 6". The "nut" on the end of the clean-out cap was a little smaller than 1.75". So looking at the photo, I'm going to say the cap was 3", so I guess that means that the ID of the biggest pipe was 3".
If I said 6" before, that's my mistake. I don't have tons of PVC experience and always forget that it's ID, not OD, and then estimating size from 10-15' away in the dark is not my strong suit.
Old 05-07-2021, 10:00 AM
I think it looks like 6" from the pics. I just think that is big for a house. But maybe you like your salads and beans. Good luck
Old 05-07-2021, 10:52 AM
Brew Master
cabmandone's Avatar
Looks like 4 to me. Can't believe we're on page 4 on a subject about poop pipes.
Nick
Old 05-07-2021, 11:03 AM
Brew Master
cabmandone's Avatar
Just remember, sh.t don't flow uphill and the liquid can't outrun the solids or the pipes get plugged with poo.
Nick
Old 05-07-2021, 11:06 AM
...and hots on the left, colds on the right.
Old 05-07-2021, 11:18 AM
Home of the Whopper
I would bet its a 3" line.
Old 05-07-2021, 11:29 AM
Brew Master
cabmandone's Avatar
How much are we betting?
Only reason I think it's 4 is the 2" coming into the back side of that Y in the pic above that then hits the 90 and goes to the pipe in the ground. Looks like 4 to me.
Nick
Old 05-07-2021, 11:37 AM
Jolly Amaranto's Avatar
At least the pipes I have been dealing with at the "country" place are out in the open when you dig out around them to expose them. Here I was adding a run to another building and taping into the main where it comes out from under the slab. Had to dig very carefully as there are all the other utilities buried there too. Fresh water, propane, power, telephone and TV coax going to another building. I stuck a long sweep elbow in the existing pipe to tap into. Also added clean outs on both the black water and gray water lines for good measure while I had everything exposed.
Old 05-07-2021, 11:45 AM
Still here
pmax's Avatar
Crawl under and measure it before this escalates !
Old 05-07-2021, 12:17 PM
Hahahah - middle aged guys on an internet forum, I'd expect nothing less. And I'm just as guilty as the next guy, so I'm all in at 4".
1972 911T/S MFI Survivor
Old 05-07-2021, 03:30 PM
Brew Master
cabmandone's Avatar
We gotta make sure Steve doesn't bet though and keep him from being influenced by BK because Steve said he thinks it's a 3".
Nick
Old 05-07-2021, 03:48 PM
Hahahah, don't hold your breath. I'm pretty unlikely to get back under there unless I really have to.
Old 05-07-2021, 03:56 PM
Brew Master
cabmandone's Avatar
You have to! This must be settled!
Nick
Old 05-07-2021, 04:07 PM
Please!
Old 05-07-2021, 05:24 PM
