Burning Ring of Fire!
Thunderstorms here twice in the last week...lots of limbs down. Power out for 4 days between the 2 storms.
Cut the limbs up and made a pile. Today...no wind...green grass...perfect for burning the pile. Had about a quart of drain oil, which I mixed about a quart of gasoline with it. The limbs hadn't dried good, so I knew I needed some help getting it started. The pile was over head high. I stuffed some paper in the bottom and poured the mixture over the whole works....and lit a match..... My mistake was waiting too long to strike the match...the fumes spread out way beyond the pile. 90 degrees out...I was wearing shorts. I no longer have leg hair! Other than that...I'm fine.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
I sure hope you have video of it!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Well.... at least ya picked a good day to put on some shorts!
Could've been much worse
Never use gas. I’ve seen the boom!! Diesel in a Hudson sprayer.
Yeah, that's a big NO NO on the gasoline part of this equation. The fumes will ignite way before it ever reaches the pile of limbs/paper/oil.
I figured a 50/50 mixture w/drain oil would eliminate the danger.
I shook it up good before pouring it on also! Plus...the 90 degree temp today didn't help either.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 08-26-2021 at 11:45 AM.. |
One of my buddies can tell a great story of when he was a kid. His dad wanted to just burn the leaves from the heavily wooded house the live at. His dad had a 55 gallon drum and welded up a grate to hold the leaves off the ground and let air in. He figured once they were burning, just keep tossing in leaves. Of course the leaves were a little wet from dew, so his dad pours on some gas the throws matches in. Nothing. More gas, still nothing. More gas one more tossed in match and my buddy said next thing he knows is he is laying on his back next to his dad, his ears are ringing and there is a volcano of burning leaves erupting from the barrel. His dad jumped up and started yelling to stamp out the falling leaves that are on fire. He can't hear his dad due to the ringing in his ears, but he figured he better help put of the fires before the neighborhood has a forest fire.
They put out all the leaves, and neither of them were hurt. He said his dad came to his room that evening when he could hear and said we will never speak of this day again.
Control Group
^^^ It was mixed with drain oil....just not enough drain oil.
When I worked in the PT department of an acute care hospital, I worked on a guy w/ burnt legs (mostly 2nd some 3rd).
He had a brush pile, put some diesel on it, but lit it standing in a shallow dip in the ground that was downhill from the brush. Filled with diesel fumes, it went "woosh" around his legs. Worked on another guy, he was working in the engine bay of his boat wearing a speedo, something went "woosh" and he had 2nd degree over most of his body. Things I never fark around with are flammable gasses and electricity. |
The Unsettler
Thought this was gonna be about Hemorrhoids
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
We have a pizza around here called the Burning Ring of Fire.
Yup. |
Be careful with the size of the pile also. Years ago I had a very large pile of limbs and brush to burn. I thought to myself, "Wow, this pile is pretty big." I lit the thing off, and soon had to back away because of the radiant heat. I had a black, heavy duty garden hose with a spray nozzle on the ground maybe 25+ ft. away in case I needed it. My wife said, "Look at the hose.' I looked and it had water squirting out if it in three places from the radiant heat weakening the hose so the water pressure could burst through. Learned a lesson that day.
Marv Evans '69 911E |
No...I was wearing shorts and underwear.
The 'Ka-Woosh' was enough to make the turtles hit the water.
Ayo Irpin, Ukraine!
I sometimes get that after Pizza, especially if it's the Pizza My Heart, 40 garlic clove...
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
I see you
BTDT too. I imagine that the oil would have resulted in a serious column of smoke.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
I just googled that. Wow, I'd risk a burning ring of fire for that pizza!
