An awesome set of TV repairman tools should suffice.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Yep, duct tape AND JB Weld!
Flex Seal, Gorilla Glue and tie wire should fix her up.
It should be back in the air in a week or so.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
FUSHIGI
Planes and coffee punks are dangerous.
Cults require delusions. |
Looks like they knew there was a potential issue. Note emergency vehicles all lined up with their lights on.
Sold: 1989 3.2 coupe, 112k miles |
Super Moderator
Just came here to say this....
https://youtu.be/qPk23hPooKY
Don't know if I linked this correctly. Juan Browne's "blancolirio" channel on YouTube has a good initial look of this event. Juan is an experienced 757 pilot.
Gary '85 Targa (fastest), '74 914 2.0 (funest), '71 VW Westfalia (slowest), '16 Q70L (wife's), '17 Armada (daily driver) |
That may not be as bad as it looks. The fuselage separated at what we call a "join ring" between two major sections. The sketch below shows where these sections go together on most traditional aluminum commercial aircraft. I'm not familiar with 757 specific body section numbers, but if that were a twin aisle aircraft like I used to fly around and fix, the section numbers would be "41 section" for the cockpit, "42 section" from the back of the cockpit to the leading edge, "44 section" from leading to trailing edge (shown in blue), "46 section" from trailing edge to empennage, and "48 section" holding the empennage.
![]() So, this thing separated between the 44 and 46 sections, right on the join ring. Not surprising with it side loaded and bouncing like that. And, believe it or not, entirely repairable. Just depends on the value of the aircraft, cost of repair, and the insurance company. Just like your car. One factor that does not come into play with your car, however, is availability of a replacement, and schedule commitments. Airlines will often pay the difference between the value assigned by their insurance carrier just to get it back in the air to meet those commitments. Maybe not at this time, with lots of airplanes parked, which may decide its fate. It is, however, entirely repairable from a purely mechanical perspective.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Insert Tag Line HERE.....
They lost the left hydraulics after takeoff, went into holding, ran the checklist and returned to land. They had no left reverser and no ABS and no nose wheel steering, among other things.. At most any other airport they would have been fine but this one had a ditch just off the side of the taxiway and they slid down in it..
Marc |
'77 S with '78 930 power and a few other things. |
Though I can't say for sure, likely an overweight landing if they had recently departed. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
(the shotguns)
Don't they have a rear door for taking the packages out?
Could we get a meme with Tom Hanks holding a stop watch superimposed?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Question-if they lost left hydraulics, would it have been dangerous/difficult to hold and dump fuel-its costa rica, could get out over water easily, and it seems they circled to run their checklists.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Behind the Sun
Without brakes could you've gone to Mexico City or even Houston for a longer flatter runway?
Is that possible? |
Edministrator
What's with a ditch alongside the runway?
Good post? Leave a tip! O - $1 O - $2 O - $3 |
FUSHIGI
Costa Rica = rain runoff management?
https://avherald.com/h?article=4f719c2d&opt=0
1978 SC coupe #1834 |
Team California
![]() Even if it could be riveted back together, I'm picturing a collection of wires and hydraulic lines severed that makes a BMW e38 look like a Model T. Endless CELs for the next owner. PASS.
Denis |
Edministrator
As Garp would say, it’s been pre-disastered.
Good post? Leave a tip! O - $1 O - $2 O - $3 Last edited by Steve Carlton; 04-10-2022 at 03:36 PM.. |
Data Farmer
Can I reset the error codes at home or do I have to take it to a dealership?
