Best broken underground PVC pipe fix?
What's the best way to fix this? This morning, the missus went out with the grandsons and came back a min later "there's a puddle outside" which is bad news since we are in a drought.
This is what I hate about PVC. If you have to cut out a broken piece, you're then left with something too short or otherwise off for a straight forward fix. I'm hoping someone can tell me the magic secret.
The exposed 3/4" between the T and the 45º is .9". So that might be enough to put a male/female coupling then connect a 45 to the end of that, but then what to do at the other end of the 45º? If I use a regular female/female coupling, how do I get everything back together without bending/breaking more sheiße? In the past, I've used screw together couplings that enable a direct fit. And if there's a direct break in the future, hopefully, just unscrew one end. But I have to think that's not the "best/right" way to fix it.
Old 08-03-2022, 01:15 PM
Control Group
Tobra's Avatar
Cut that off flush with the cracked piece and you will have plenty to work with
Old 08-03-2022, 01:22 PM
My brother has something similar going on at his place only his break is under concrete.
Scott
'78 SC mit Sportomatic - Sold
Old 08-03-2022, 01:26 PM
Yikes! Yeah, from that point of view, I'm pretty lucky.
Old 08-03-2022, 01:27 PM
Control Group
Tobra's Avatar
it could be worse, no jackhammering involved.
I was only trying to help you see the brighter side of things. Mud you can dig in, concrete, eh, not so much.
Scott
Old 08-03-2022, 01:29 PM
It almost looks like the T-fitting has a reducing bushing in it for the pvc pipe?
If it is...then saw it off at and turn that bushing out. Replace with a new bushing and cement in the rest.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 08-03-2022, 01:38 PM
Thanks guys. Now what tetris combination do I need to do the fix?
If I use a straight 3/4-3/4 coupling, my PVC will be too far away to then use a 45º elbow.
Old 08-03-2022, 01:39 PM
Yes, there is a reducing bushing. I think the other 2 legs of the T are 1" and that is a 3/4". How would I "turn that bushing out" while the T is in the hole?
Old 08-03-2022, 01:40 PM
Yeah...thinking more about that, the bushing is prob glued in, instead of threaded.
My idea of unthreading it prob won't work.
If there isn't enough room to attach a new fitting to the 3/4...how bad would it be to replace the whole T-fitting?
(If it could be turned out...it would have the nut edges)
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 08-03-2022, 01:45 PM
3rd_gear_Ted's Avatar
12" either side of all that stuff to have the pipe flex needed to re-assemble it all with correct tension on the connections.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 08-03-2022, 01:51 PM
Cooper911SC's Avatar
Another option
Old 08-03-2022, 02:15 PM
Platinum Member
dad911's Avatar
Edit, beat me to it.
Old 08-03-2022, 02:18 PM
MBAtarga's Avatar
I'm disappointed no one has offered the ultimate solution yet!
Mark
'83 SC Targa - since 5/5/2001
Old 08-03-2022, 02:21 PM
I see you
flatbutt's Avatar
There's always the Flatty fix. Tho I imagine It'd be higher than the amount shown
Old 08-03-2022, 02:22 PM
Control Group
Tobra's Avatar
Cooper, where has that stuff been all my life
Old 08-03-2022, 02:27 PM
1. cut off the damaged 45 fitting as close as possible to the fitting on both ends
2. this should leave to the right side the .9" you mentioned as a 3/4" stub out
3. then trench backwards along the left side pipe (as shown in the pic) so the pipe can be moved to each side a few inches.....go back at least 12-18"
4. then cut that pipe about 12" back from where the damaged 45 was
5. with a new 3/4" coupling - PVC glue on a new section of 3/4" pipe - use thin wall - not schedule 40 - a bit longer than what you removed - 15" probably ideal
6. then glue a new 3/4" 45 onto the stub out and then let it sit for at least an hour to set up good
7. move the new piece of 3/4" pipe over and above the new 45 - and make a mark on the pipe where to cut in order to properly fit into the 45. It's OK if it's a hair too long as the added pressure will help hold it in better. Just not too much - a very fine line here
8. then cut where marked, glue it in, then let it sit for a 1/2 hour - then test
When you do the last connection you will have to bend the left side pipe a little to get it in the new 45 - lifting the pipe and connection up a bit always helps when you do this.
Good luck!
Old 08-03-2022, 02:43 PM
Originally Posted by Cooper911SC View Post
Another option
This is another good option if you can find this product. Already pre-glued to the fittings which is good. Because gluing flex pipe and PVC fittings together can be a little tricky. Certain glues work better than others.
If you go this route I recommend gluing one end into the stub and letting it sit for at least a 1/2 hour before doing anything else to make sure it welds up nicely - given you are working with such a short piece. The rest should be self-explanatory.
They are in stock at my HD:
3/4 in. x 18 in. PVC Slip Flexible Repair Coupling
$11.52 - that's not bad.....
Old 08-03-2022, 02:48 PM
craigster59's Avatar
Another option
I used this to repair a sprinkler line a few months ago. Worked like a charm!
Old 08-03-2022, 03:29 PM
Hahah! That’s exactly what I thought to myself when I first discovered these at HD and ACE a few years ago! 😎
It has made repairs and some installs in funky shaped planters a breeze!
Old 08-03-2022, 03:32 PM
