Best auto under coating in wheel wells?
What is the best durable under coating to use in wheel wells? And what is the best primer/base to use before the undercoating?
I’ve got one flare built (but needs finish work) and before I undercoat it I need to spray a primer or something I’m thinking.
I can't exactly answer your question, and I assume weight is a consideration. I know that years ago, there was undercoating at most FLAPS. I imagine it was permatex brand or something like that. These days, rhinoliner might be a good option. I think that's available thick, thin, smooth, bumpy, etc....
I would think a layer of primer and a layer of paint would be all you need, help keep it from rusting away, problem with undercoat is when you need to go in and repair.
87 930, |
Get a couple cans of this you will be good to go. Let it cure 24 hours. Its dries like a rock.
Jeff Hail "All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible" |
Leadfoot Geezer
This stuff works pretty well. No primer needed.
'67 912, '70 911T, '81 911SC, '89 3.2 Targa - all sold before prices went crazy '25 BMW 230i coupe - current DD '67 VW Karmann Ghia convt. & '63 VW Beetle ragtop - ongoing projects |
Counterclockwise?
Without prep, are you not trapping the oxidization/rust in?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
That’s why I think I need a primer or sealer of some kind before I put a final coat of Wurth or similar under coating or epoxy paint. Of course I need to prep everything with a wire wheel and sanding disc.
Fleabit peanut monkey
I better understand what you are looking for now. Let me look in my stash. I may heve some pre-primer etching stuff I could send you. Still pissing the day away drinking coffee at home. Off to the shop shortly.
1981 911SC Targa Last edited by Bob Kontak; 12-22-2022 at 07:32 AM.. |
I would go with what Jeff Hall recommended then the Wurth or Gravitex. You could use OSPHO to acid etch the bare metal before using the 2 part primer sealer but there is a process to that but well worth the effort.
1981 911SC Targa |
I think when it starts to show some rust, it's too late for any miracles.
I’ll look into that. I have been been using Sem self etching primer.
