Functionista
![]() Well the magnet didn’t look so bad and the fluid is still in good shape. I will have to check with the first owner, I seem to recall him saying he got the transmission replaced under warranty. But that might have been another vehicle I bought from him…. |
Functionista
Nope, he said original trans, actual mileage is 134K.
I’m hoping the cooler temps here keep it surviving.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
I get nervious when my 4r100 gets that high.
dolor et pavor Copyright |
Functionista
Yeah, before I changed the filter I saw about 196 driving up a mountain pass (2000 foot gain), in around 50F temps. I will see if any temp drop occurs next week. My Suburban does have the tow package so maybe a bigger cooler but I’m not sure….
I’m putting a 6L80e hooked to a 5.3 (LC9) in my ‘85 Land Rover Defender. Turns out there are a few things you can do to help the 6L80e’s reliability. One is to replace the flex plate, as the factory plate tends to flex & ultimately crack. Pretty easy to do. The second (as alluded to earlier) is the Sonnax ZIP kit. It’s a series of upgrades that ‘fix’ some of the inherent weaknesses. I did mine in about a day. https://youtu.be/0YEzuUsXITE
Also search for Gary Ferraro on YouTube.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
A very good friend had a 2015, be bought new, not a lot of miles and definitely not ha4d. After his 3rd transmission under warranty and it was close to out of warranty, he went and traded it in on a new Ram when they were making good deals on them. He is still very happy with it.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Ms Rockets 2010 Tahoe has 250,000 miles. No issues to date. I’m not sure what transmission that has.
I got 200,000 miles out of the transmission in my 2001 F150 when I had to rebuild it. I’m at 178,000 miles with my 2014 F150. Knock on wood, it’s still good. |
Interesting read. Why didn't GM just put in a known durable Allison transmission in their trucks like their old diesels? It is that much more? I understand its only a 6 spd and may not be a fuel efficient. After all, I think they own Allison?
Ram dumped Aisin for a reason and it wasn't bc they're more durable than the 68RFE....
Does it cost that much more to have a Allison then the typical GM tranny? I am asking because I have no clue. |
This is different than dodge that just sourced the cummins and aisin, then shipped it all to Mexico to be put together.
I also have the new thermostat - did a 10hr road trip today, MA into VT and back. Highway, mountain roads, soft and muddy dirt roads, etc. Temps averaged 121-140F. They used to be 190-194F no matter what, that's what GM had them set for. He also highly recommends synthetic trans fluid. The line item part cost for the t-stat was $84, but there's no part #. I'd recommend that since you are in CO pulling grades, and it should be easy to do. |
Functionista
Is the new t-stat a superseded part from GM? I did see where guys reverse the internal “pill” in the OE t-stat to create a straight bypass. Usually drops temps into the 140F range. Wonder why GM wanted the operating temp up high? Synthetic Dexron VI in mine. I still haven’t taken a long drive up hill, been really cold of late too.
Check out this guy. Seems that GM transmissions are a bit of a specialty for him.
https://m.youtube.com/@performancetransmissionsll1573/videos#bottom-sheet Sent from my iPhone using Tapatalk |
