Will give my input later tonight. Fairly simple process.
Old 03-19-2023, 03:06 PM
Bill Douglas's Avatar
Thanks Super. You are giving me some good ideas
Old 03-19-2023, 04:42 PM
Senior Member
Superman's Avatar
That's great Bill, but just don't post pics.
I think it's likely just a matter of me getting some of that hose that dribbles every six inches, and some connectors and a plug for the end and a connector to the hose or hose bib.
Mocha 1978 911SC. "Coco"
Old 03-19-2023, 05:55 PM
wdfifteen's Avatar
Originally Posted by Superman View Post
Any further descriptions would be helpful, as I do not fully understand. You and wdfifteen seem to be pointing to the same system. Looking at the link, the 50' roll seems to be a different animal from the 100' roll. One seems to have dribble sections and the other does not. There are connectors and plugs which are often bought at the same time, but I do not understand what they do. Perhaps start by describing the system. One long line with dribblers every 6"? Or a non-porous trunk line with separate branch lines for each tree with (maybe) dribble nozzles? Pressure regulator?
Monkey and I are describing similar systems. The one he posted is a plastic line with slits cut in it every few inches (or feet, depending on which one you get). I have one of those for my bedding plants.
I like this one for individual plants that are relatively far apart. I use it for my tomatoes, which I plant 6 feet apart. It starts with a pressure regulator. Then a 1/2 inch solid plastic "hose" (line). The pressure in the line is fairly low, but I can't say exactly what it is. The system has little barbs that you can push into the line at whatever interval you want to tap into it. The barbs connect to a 1/4 inch line that has an emitter at the end that regulates the volume of water that flows. You place the emitter at the base of the tree. The emitter "emits" water at a specific gallons per hour rate. It's really that simple. I use this system to water individual plants because it doesn't waste water on the ground between the plants. It seems perfect for your trees. Based on your picture, I would run the 1/2" line about 3' off the ground through the branches of the trees to keep it off the ground and drop 1/4" lines down to the ground under each tree.
You can push the barbs in at whatever distance your plants are, connect a 1/4" line to it with a 2 GPH emitter at the end that will drip 2 gallons per hour at the base of every tree.
As I said, as a check on the amount of water the system is REALLY delivering, you should add a 1/4" line and emitter drop and have it drip into a container so you can monitor the actual amount of water that is being delivered by the system.
For a run as long as yours you might install two monitoring drops, one at 75' and one at 100' to see if they are getting the same amount of water. If they aren't the same you may have to use 1 gph emitters and run the water longer. The emitters cost about $10 a dozen, so no big deal.
I will be happy to draw you diagram in the AM. Right now I have a warm woman in a warm bed calling.
Old 03-19-2023, 06:17 PM
GF is doing much the same at her place and using griselinia trees. She said she is going to setup a watering system that is below the surface so it doesn't evaporate off and gets to the roots.
Information Overloader
You might consider putting landscape fabric down before mulching. That drip line is gonna promote uncontrollable weed growth, otherwise.
Old 03-19-2023, 06:50 PM
I planted fifty arborvitae trees a week ago that range from 5-7' in height. One of the best ways to kill these young things is to fail to adequately water them. Starting now of course but particularly through the upcoming summer. I hope to set up an automatic system.
I intend to bring in some mulch (bark, basically) to reduce evaporation. I have hoses and timers but I do not know what type of irrigation lines to use, or what type of dribble-nozzles to use. Hoping for a solution that is cheap and easy to implement.
Please offer your thoughts and suggestions.
Supe......
50 trees planted at 3' centers = approx. 150 linear feet, right?
So, SM was on the right track but the link he provided in his post was for QUARTER INCH Rainbird drip tubing.
What I would use is the HALF INCH size Rainbird drip tubing.
Typically available in 100' and 250' rolls.
Here is the 100' roll from HOME DEPOT: CLICK
And the 250' roll from Amazon: CLICK
I gave you two different vendors so you could read reviews, etc. and look at other related stuff they always show you.
For 150 liner feet you could go two different ways:
1) Serpentine the tubing so it goes in and out between each tree much like a dog running Agility weave poles. If you do this method you'll probably only use 200', or less.
2) Run two lines - one on either side of the trees - parallel to each other. Keep the tubing about 6" off the trunks. Using this method you'll need approx. 300'.
This tubing has a (drip) hole (emitter) every 12", and as Scott said the objective is just to soak the ground where your roots are. So you don't need a ton of water pressure/volume. What comes out of your garden hose would probably be plenty enough.
The tubing is held in place by ground staples. Get the ones with the round tops - not the squared off ones. They are about 6' long and you just push them into the ground about every 2' or so....maybe even longer depending on your layout.
The tubing comes wrapped in saran wrap. Leave the wrap on and when you install the tubing walk backwards while unrolling the tubing while holding with your hands in the center so it unrolls itself out of the wrap, so it doesn't get twisted. You do not want any kinks!
If you need to connect two sections they make couplers. You can push these on but it helps if you have warmer weather so the tubing isn't rock hard and stiff. I never used hose clamps but some folks do.
At the end of the tubing when you want to close it off simply fold the tubing over about 6" from the end and tape it closed with Gorilla Tape.
If you have an irrigation supply house nearby, you could buy everything you need there and save money as well as get questions answered.
You could also go to You tube and do a "Rainbird drip tubing" search and find probably all kinds of info.
I've used this stuff for many many years with great success and for your application it's the perfect choice.
After the drip tubing is installed, a layer of mulch on top would also really help with conserving water and also weed management.
I have a ton of photos from previous projects I used this on but doubt you need any.
I didn't go into timers but nowadays they make all kinds that make life easier. Happy to provide my take on that iof you want - just let me know what water source you are using. If it's a hose bib just get a battery operated one like this: CLICK
Water every day for 1 hour maybe and see if that's enough.....
HTH and good luck, brother!
Old 03-19-2023, 07:01 PM
Senior Member
Superman's Avatar
Each of the trees came with its roots encased in burlap. So....I have a pile of burlap pieces that are about 2.5' squares.
I think I like the idea of two lines of tubing that drips every 6", in a figure 8 pattern, crossing between trees. This achieves what SM says is an important water 'range" under each tree to promote root expansion. I think the trees were harvested with a clamshell machine that cuts off all roots outside the immediate ball of around 16" diameter. These things need to rebuild those cut-off roots.
Senior Member
Superman's Avatar
Thanks, Baz. The Orbit timers are the ones I have, and there is an irrigation supply house nearby. I think I will throw them some business tomorrow. Your explanation is understood and your suggestion to use 1/2" line is important, I suspect.
Old 03-19-2023, 07:10 PM
Excellent - the supply house will be very helpful. Remember - get the staples with the ROUND tops....not square.
Also, the 1/2" is standard in the landscape business. It's used all over the world. The company who first got it started was called Netafim. I just happen to prefer the Rainbird brand tubing.
The 1/4" tubing is sometime used for small planters and potted stuff - not so much for landscaping. Too small.
Also, I never liked figured 8-ing the tubing because that makes it cross over itself. I prefer no crossing over. All tubing in direct contact with earth.
Just my preference.
Best and good luck!
Old 03-19-2023, 07:34 PM
A930Rocket's Avatar
I don’t understand the reasoning to have a drip every 6 inches or 12 inches? Seems you would want the drips at the tree, which would be every 3 feet. Maybe two drips at each tree?
Old 03-19-2023, 07:38 PM
The Unsettler
stomachmonkey's Avatar
Supe......
About f'n time you showed up.
My bad, I just looked at the pic and didn't check the size cause I figured you'd eventually chime in set us straight anyway.
"I want my two dollars"
"Brandon Won"
Old 03-19-2023, 07:55 PM
The Unsettler
Because you don't want to water just the trunk.
You want to water the ground around and away from the trunk to encourage root expansion.
If you were relying on mother nature and only rain you'd get the most water at the outer circumference of the canopy, the dripline.
The root system will expand as the tree grows and the dripline expands.
You want to encourage root growth out and away from the trunk.
If you water just at the trunk the planting may stay root bound which is not beneficial.
Trees stay in the ground because root spread anchors them better, if they stay root bound they will eventually get too large / tall and will uproot themselves especially in strong winds.
"Brandon Won"
Old 03-19-2023, 08:05 PM
Plus, that’s how it comes from the store.
Old 03-19-2023, 08:11 PM
The Unsettler
There are two basic types of couplers.
Barbed which you just push into each piece of pipe.
Perma Loc, they have a screw on collar, think brake lines, a couple of pennies more and a tiny little bit really insignificant more work.
I used to use the barbed but switched to Perma Loc because the extreme temperature swings in my area causees ground expansion / contraction and I've had the barbed type pull apart on occasion.
"Brandon Won"
Old 03-19-2023, 08:20 PM
Platinum Member
dad911's Avatar
We used standard soaker garden hose in a similar situation. screw together, simple. Loop around each tree (dripline) and simple programmable garden hose timer.
Once they are established, you won't need a permanent system.
Old 03-20-2023, 06:57 AM
MBAtarga's Avatar
We tried that Rainbird hose product that weeps every 12" or 18". It was lousy. Very inconsistent watering pattern along the length. Watered much heavier on the inlet end - and even lowering the pressure didn't help equalize the pattern.
I'll post pics later - we used the Rainbird 1/2" solid hose with the 1/4" flexible line and drippers in our garden. We've been very happy with the results. The drippers come in multiple variations - we used the 2 GPH on tomatoes and 1 GPH on the pepper plants. An automatic timer makes it labor free once installed and set up.
Edit - remembered I've already posted pictures of the garden. On this thread below you can see the black 1/2" line with multiple drippers connected via the 1/4" flex hoses.
http://forums.pelicanparts.com/off-topic-discussions/1119361-2022-vegetable-garden.html
Mark
'83 SC Targa - since 5/5/2001
Old 03-20-2023, 07:03 AM
wdfifteen's Avatar
I don't understand it either. You don't need to water beyond the reach of the branches.
From the web:
"The area beneath a tree's drip line is called a critical root zone or a protection zone. It is very important to a tree since the most critical tree roots are generally found beneath the soil in that area. These roots are the ones that need the most protection and nurture. This zone must not be disturbed if the tree is to remain healthy."
Two or more drip emitters at every tree within the drip line would be better than than wasting water in between trees. I use one of those Rainbird soaker-type hoses with the slits every foot in bedded plants and they deliver water inconsistently along their length. I haven't found a way to monitor the output from them very easily. I see dry patches when I use it in my strawberry bed and move the hose, but who wants to do that on a 150 foot run?.
Old 03-20-2023, 07:29 AM
Senior Member
Superman's Avatar
The trees' driplines are currently, wider than their roots. This, because they were harvested with a clamshell machine that cut off everything outside about a 16" clamshell digger bit. Those need to regrow. Watering outside the 16" root circle is needed to encourage roots to grow out TO the dripline.
But the dripline will change as the above-ground part of the tree grows. They will widen, eventually touching each other. This is why water is needed between the trees and outside the current dripline.
Right now, the roots are confined to a 16" circle. Which is, basically, the reason why I need a 30" wide wet area.
These reports of uneven water distribution from the Rain Bird 1/2" drip tube....are unsettling. Baz?
Targa, I would not expect better distribution with lower pressure. I would expect the opposite. If there were 60 psi of pressure in the hose, then that same pressure would likely be found at the end of the hose. This is a question I will be asking: Can this system have full (city water supply) pressure inside the line?
Old 03-20-2023, 09:35 AM
Senior Member
Superman's Avatar
BTW, it's raining today. It might rain all day. It rains here.
The rain stops around mid-July and does not return until at least late September. With a few exceptions, of course. We are not planning for March or April. We are planning for August.
Old 03-20-2023, 09:38 AM
