So I was pumping up my bike tire...
and went for an uneventful ride the other day.
Came home and took a picture of my bike, just because that's what I do, take pictures, and noticed something funny at the valve stem on the front tire.
Any of you guys ever had this happen?
I'm bummed because the tube is a super heavy duty one I put in way back a long time ago when I switched wheels to this bike. They're heavier duty than the tires themselves.
If they'd stay on the rims without tires around them I think you could easily ride on them.
The 'heavy duty' Goodyear inner tube I replaced it with this morning is really light weight compared to what came out.
Scott
'78 SC mit Sportomatic - Sold
Old 06-21-2023, 10:54 AM
Almost Banned Once
sc_rufctr's Avatar
Yep... I've seen that a few times in the past but lately - E-Bikes!
Age plus heat IMO.
- Peter
Old 06-21-2023, 11:06 AM
HobieMarty's Avatar
It's a toomah!!!
Wonka
Old 06-21-2023, 11:08 AM
Originally Posted by hobiemarty View Post
it's a toomah!!!
Sent from my sm-n950u using tapatalk
LMAO! It's NOT a toomah!
Old 06-21-2023, 11:16 AM
Kantry Member
oldE's Avatar
Just a little embolism. If it has the chance of chafing around the valve stem hole, it will go away.
Best
Les
Best
Les
Old 06-21-2023, 11:33 AM
Data Farmer
If you ride fast enough, the centrifugal force will make the air leave the valve stem and go back into the tube.
Old 06-21-2023, 03:19 PM
You do not have permissi
john70t's Avatar
Pull inner tube.
Coat with ubtanuim coating.
Wrap a 1/32" steel hard band around the base of the valve stem.
Sue the mfr for providing cheap new parts which led to your broken neck.
Old 06-21-2023, 03:30 PM
Almost Banned Once
sc_rufctr's Avatar
I know that's meant to be funny (& it is) BUT I wonder if you'd actually be able to test that?
Imagine a really fast rotating bicycle wheel with a tiny camera mounted in such a way so it would record what's going on in the valve area.
Air has mass so it would be affected by centrifugal force but it would also be pulling a vacuum behind it. Would those two forces balance each other out? IMO the centrifugal force would be greater than vacuum up to a certain point.
- Peter
Old 06-21-2023, 04:01 PM
Zeke's Avatar
Pull it back and reinflate. Maybe a fiber washer if the fit isn't right.
Old 06-21-2023, 04:04 PM
john70t's Avatar
Is that like the F1 dilemma?
(i.e. speed up to not crash.)
Old 06-21-2023, 05:02 PM
