I see you
flatbutt's Avatar
Concealed carry requirements in NJ
I'm in favor of training but dang.
https://nj.gov/njsp/firearms/pdf/PTC_use_of_force_and_Qual.pdf
Appendix B
Permit to Carry Safe Handling and
Proficiency Qualification (HQC2-modified)
1. Familiarization Requirements for Each Participant.
a. Demonstrate the safe handling of weapon.
b. Demonstrate proper loading and unloading techniques.
c. Demonstrate the techniques of proper physical stance.
d. Demonstrate the techniques of good marksmanship.
2. Range - 25 yards.
3. Target - FBI type Q target, either paper or cardboard. Multiple targets may be
used at the discretion of the agency executive or supervising firearms instructor.
4. Course.
a. Total of 50 rounds per participant.
b. Double action is required for revolvers for all phases. Semi-automatics
are to be fired in the manner in which the individual weapon functions
normally and are to be decocked when changing positions or hands.
c. Reloading may take place at the discretion of the supervising firearms
instructor. Additionally, discretion may be used as to the number of
rounds with which the magazines are loaded to accomplish reloading
exercises during the course. Similarly, the sequence of rounds fired at a
given distance may be altered to accommodate a reloading exercise.
d. To achieve a passing score of 80%, the participant must place a minimum
of 40 shots within the border of the Q-target silhouette.
e. Physical or simulated barricades are recommended in Phase I and may
be used at the discretion of the certified firearms instructor during any
phase.
Phase I 25-Yard Line. Time: 30 seconds - stage 1, 25 seconds
stages 2 & 3 10 rounds.
Strong-side kneeling
Strong-side kneeling or standing
• On command, from a secured holstered position, assume the
strong-side kneeling or standing position, fire 4 rounds. (30
seconds)
---STOP TIME—
• Decock and remain behind cover with visual focus towards the
threat area.
• Reload if needed (revolvers will reload and index the cylinder)
• On command assume a kneeling or standing position and fire 3
rounds. (25 seconds)
---STOP TIME—
threat area. Reload if necessary
• On command fire 3 rounds, standing or kneeling (25
seconds)
---STOP TIME---
• Reload if required and holster an uncocked weapon.
• Reload loading devices.
Phase II 15-Yard Line. Time: 5 seconds. 3 rounds.
Point shoulder position.
• On command, from a secured holster position, draw and fire 3
rounds in 5 seconds from a point shoulder position.
---STOP TIME---
• Reholster an uncocked weapon.
Phase III 15-Yard Line. Time: 25 seconds. 7 rounds.
Strong-side kneeling position.
rounds from a point shoulder position.
• Assume a strong-side kneeling position. Reload with 4 rounds,
index if required, and fire 4 rounds from a strong-side kneeling
position.
---STOP TIME---
Phase IV 10-Yard Line. Ready Position.
Each drill, Time: 3 seconds. 2 rounds.
(Total 6 rounds).
• On command, draw weapon and assume a ready position, i.e.,
muzzle depressed below eye level.
• On command, bring weapon up to eye level and fire 2 rounds in 3
seconds. Repeat drill twice, firing a total of 6 rounds.
---STOP TIME---
Phase V 7-Yard Line. Time: 4 seconds. 3 rounds.
Standing point shoulder position.
• On command, from a secured holster position draw and fire 3
rounds in 4 seconds from a standing point shoulder position.
---STOP TIME---
Phase VI 7-Yard Line. Time: 15 seconds. 6 rounds.
Standing point shoulder position. Mandatory reload/magazine
change
rounds from a standing point shoulder position.
• Reload and fire 3 more rounds within the 15 second time period.
---STOP TIME---
Phase VII 7-Yard Line. Time: 4 seconds. 3 rounds.
---STOP TIME---
Phase VIII 5-Yard Line. One-handed - Strong hand.
Each drill, Time: 4 seconds. 2 rounds.
(Total 4 rounds).
• On command, draw and fire 2 rounds using only the strong hand.
• Repeat once.
Phase IX 5-Yard Line. One-handed - Support hand.
(Total 4 rounds).
• On command, draw and transfer the weapon to the support
hand. Assume a ready position.
• On command fire 2 rounds using only the support hand. Return
to ready (The strong arm should be limp along the body).
• Repeat once.
Phase X 1-Yard Line (or as close to 1-yard line as safety dictates).
Weapon Retention Position. (Begin with the support hand across
the chest with the hand grasping the collar of the shooter’s shirt.)
Each drill, Time: 2 seconds. 2 rounds.
(Total 4 rounds).
• On command, draw and fire 2 rounds in 2 seconds from
the weapon retention position.
• Repeat drill once, firing a total of 4 rounds.
• Clear all weapons. Holster a safe, empty weapo
Old 07-18-2023, 08:02 PM
Rick Lee's Avatar
AZ is: be a state resident, legally able to own a gun. Oh, and no permit required to CCW. And if you're not an AZ resident, you can still CCW, AND you're not expected to know the local rules about where you can CCW. So you're exempt from the same laws I have to follow. What a country!
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-18-2023, 08:14 PM
I see you
flatbutt's Avatar
I'll never qualify given that my "strong" hand is so badly crippled that I can't do one handed firing. My off hand is ok with .22 but no way can I safely one hand a 9mm.
No Weaver stance either, I'm limited to "cup and saucer".
Old 07-18-2023, 08:18 PM
Fastrrrrrrrr!
They don’t want you to have it.
Old 07-18-2023, 08:25 PM
Jim Bremner's Avatar
I'm well over 10k rounds
Paid for instructions from three trainers
Passed the NRA pistol trainers class
Shot in pistol comps
Rung steel at 75 yards and hit bowling pins at 100 yards
Hit steel at 700 yards with rifle
500 yards with open sites
Qualified for CCW in Californ
can put 20 rounds in an eighth inch target in 11 seconds
This will take some training to complete
I am more concerned about knowing the law to shoot/ no shoot than this level of live fire
Old 07-18-2023, 09:21 PM
Rick Lee's Avatar
When I took my NV CCW class, it was more about knowing when you could shoot vs. not shoot rather than how you did on the range quals. IMHO, that's more important. My takeaway, after the instructor showed us real photos of gunshot death crime scenes, was, if you don't absolutely have to shoot, then don't. He was a LV Metro cop and had been there, done that. I believed him. Believe me, it's nothing like on tv or in the movies.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-18-2023, 09:32 PM
You do not have permissi
john70t's Avatar
Well..duh.
"Life is a harsh teacher. It gives the test first and the lesson after"
-Quote from somebody
-Because Bing Search only returned half a random page and no more.
Old 07-18-2023, 09:50 PM
Same in Oklahoma. I do not need any government permission to exercise a constitutional right. I don't need a permit to speak freely, gather in groups of friends.
There are still places that teach the smart carrying common sense things, and safe and practices. It is possible to get a "license" and that is accepted in many other states and certainly a good thing to have if you want it, but not mandated.
Old 07-19-2023, 07:17 AM
3rd_gear_Ted's Avatar
In Oklahoma you can't get a CCW if you have a medical marijuana card.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 07-19-2023, 09:15 AM
id10t's Avatar
Someone subject to this BS should look up what the requirements are to pass the firearms part of police training up there... I know I've seen our standards here in Florida and they are a joke compared to what most recreational shooters do...
Old 07-19-2023, 09:36 AM
Really?
Of course, the pot heads, and drunks don't even need a license to carry.
We have more "medical pot" stores than all but a few places in Oregon. They are on every block is seems. There were more, but the realities of business, and the laws of supply and demand hit a lot of them hard.
Old 07-19-2023, 10:24 AM
Really?
Yeah, I saw the TV show.
Old 07-19-2023, 10:25 AM
Here in PA you just have to fill out the form. Usually in and out within 15 minutes. We have a very pro Second Amendment Sheriff in our county. I have heard that it is more complicated in other counties. State law is pretty clear but not always followed by elected officials.
Old 07-19-2023, 11:59 AM
I see you
flatbutt's Avatar
That's SOP here in jersey. Officially they are supposed to issue a purchase permit within 30 days. They never do.
Old 07-19-2023, 12:36 PM
Parrothead member
VINMAN's Avatar
Just another way of discouraging people from applying.
But yeah should have some training and ability to hit a target.
Vinny
Old 07-19-2023, 12:43 PM
canna change law physics
red-beard's Avatar
Those requirements look like they were cribbed from a police training course. Getting behind cover. Kneeling position. 80% hits at 25 yards?
James
Red-beard for President, 2020
Old 07-19-2023, 02:48 PM
Make Bruins Great Again
Por_sha911's Avatar
seconds)
---STOP TIME—
threat area.
---STOP TIME—
seconds)
---STOP TIME---
---STOP TIME---
position.
---STOP TIME---
(Total 6 rounds).
---STOP TIME---
---STOP TIME---
change
---STOP TIME---
---STOP TIME---
(Total 4 rounds).
• Repeat once.
(Total 4 rounds).
• Repeat once.
(Total 4 rounds).
Phase 11: hop on one foot and spit wooden nickels.
Phase 12: Realize that all this is mandated to discourage anyone other than people with marksman skills to ever be able to carry a weapon.
Phase 13: Vote for DIFFERENT POLITICIANS to get out the jerks that created phases 1-10!
Phase 14: MOVE out of state!
Joe
Old 07-19-2023, 03:04 PM
I've owned various handguns for more than 35 years... but tonight I have to attend the 2nd 4-hour course of the new 16-hour mandated class in NYS to maintain my license.
I have to pay someone $500 to hear that a gun should always be pointed in a safe direction and consists of a barrel, frame, and an action.
This thread could go to PARF in a NY minute, as there is only one party that pushes this nonsense.
Ken
1986 930 2016 R1200RS
Old 07-20-2023, 01:11 PM
Control Group
Tobra's Avatar
What percentage of NJ cops could pass the CCW permit requirements?
Old 07-20-2023, 01:20 PM
I think after passing the qualifications, that also automatically puts your into the local FBI office's marksman team. LOL!
I think the Texas shooting is 50 rounds. 20rds @ 3yds, 20rds @ 7yds, and 10rds @ 15yds. I don't think the requirements at any of those distances were very high. I don't think you had to do any shooting one handed. As a matter of fact, I would be surprised for anyplace to require that. I'd think that they'd prefer to promote 2 handed shooting.
Wow. When I got my license in TX, I think the "class" (including shooting) was either 8 or 10 hours (2 hours was reserved for shooting with the rest as a required minimum for the classroom training).
I think they eventually knocked it down to 4 hours. And now you don't have to have a license. Although, you can still get a license, and having a license does give you a little more permissions than not having one.
Old 07-20-2023, 01:42 PM
