Mini-split line brazing - I question this method
I'm upset. A company, supposed to be one of the best, is installing a mini-split system in my house. See picture. I can't believe this method of connecting two diameters is considered approved or a best practice. It looks like he pinched the larger line so that a braze joint could be attempted. I think a quality flare joint is preferred at this connection point. If someone says it is done all the time, that is really not a good answer.
AC technicians please comment.
Thanks.
Sold: 1989 3.2 coupe, 112k miles
Old 09-09-2023, 06:13 AM
Bland
unclebilly's Avatar
The solder that wicks into the annulus between the tubes is what gives the seal, not the ugly part you see. If the overlap is an inch or so,it will be fine. Better than any flare.
Old 09-09-2023, 06:40 AM
Disagree. That’s a poor job. He should either used a reducing adapter or an expansion tool to step / stretch the one line to fit over the other.
And dollars to donuts: the guy that was ok with that method did not back purge with nitrogen, so you’ll have all sorts of carbon particulate circulating forever in your system. Ugh
Ken
1986 930 2016 R1200RS
Old 09-09-2023, 06:47 AM
Yes, that's exactly what I'm thinking. Should have used an expansion tool or reducer. Also, I'm having a hard time envisioning how nitrogen can be flowing very well if it has to flow through the outside unit pump/etc. The nitrogen is supposed to be FLOWING.
Old 09-09-2023, 06:54 AM
Bland
unclebilly's Avatar
Originally Posted by gsxrken View Post
Disagree. That’s a poor job. He should either used a reducing adapter or an expansion tool to step / stretch the one line to fit over the other. … Ugh
So you are saying this won’t work?
You’ve calculated the shear strength of the solder in the annulus, the shear strength of the solder bonds and drawn this conclusion or just an opinion?
The reducers make it easy but not necessarily better. Ever seen how a brass radiator is made?
Old 09-09-2023, 06:56 AM
I concur, workable or not that is just sloppy and lazy work. I’d be worried about the rest of the job. This is someone who has no pride in what they do, IMO.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2025 Ranger Raptor
Old 09-09-2023, 07:06 AM
FUSHIGI
That's BS workmanship. You should be pissed.
Cults require delusions.
Old 09-09-2023, 07:07 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I'm with unclebilly.
What do you want strength or beauty?
1981 911SC Targa
Old 09-09-2023, 07:38 AM
Ha ha...I'm with Bob....
Old 09-09-2023, 07:51 AM
I am pissed. They are going to try and work today but my thinking now is to shut the job down until this gets resolved. To start with they said there would be very few if any brazed joints and now I have brazed joints all over the place. I watched as they flowed nitrogen and they cut it way down probably because one end wasn't open. I'll try to contact Mitsubishi on Monday.
Old 09-09-2023, 07:54 AM
908/930's Avatar
The clearance between the two tubes should be about .002"-.005", looks like about .03" on the small tube. I am curious how much overlap he did.
Check the installation manual and see if they give a brazing spec? Good luck.
Old 09-09-2023, 09:25 AM
Update - They got some proper adapter fittings and are putting them in now. Unreal.
Old 09-09-2023, 09:44 AM
UnRegistered User
billybek's Avatar
It is done.
It does look kind of crappy.
I agree that a swedge would have looked nicer but they are dissimilar in size.
It shouldn't affect performance and if the joint is filled with silphos solder, there shouldn't be any possibility of moisture getting into the joint and freezing. This can cause problems with outdoor piping over time.
A reducing fitting would look better and more professional.
Bill K.
Old 09-09-2023, 09:47 AM
Kantry Member
oldE's Avatar
I suspect if you took a peek at the back of your refrigerator or the reefer unit on most trucks, you would find identical joints. That joint isn't pretty, but it is unlikely to fail.
Best
Les
Best
Les
Old 09-09-2023, 09:57 AM
Looks like you had oversized lines installed.
I wonder what the difference is ...
Chris
the more i learn, the less i know
Old 09-09-2023, 11:36 AM
Bill Douglas's Avatar
I think it will work fine if it is brazing - not solder. Just a bit inelegant looking.
I do my own plumbing as a hobby and to save money, and I definitely would have used a reducing adaptor. And brazed it using silfos. As an amateur I tend to be extra tidy and over engineer everything to be on the safe side.
Old 09-09-2023, 11:46 AM
sc_rufctr's Avatar
The joins are ugly for sure but if they're hidden and reliable does that matter?
It doesn't to me but if you can see those joints then it's worth fixing.
- Peter
Old 09-09-2023, 11:54 AM
peppy's Avatar
I see a lot of refrigeration work around the restaurant and it's pretty common joint.
I saw a man crimp down the inside line and make a temporary expansion valve. it worked fine until we could get the correct part.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-09-2023, 12:40 PM
I see it all the time, it is and will be fine. If you are looking for beauty, then go with someone else.
Old 09-09-2023, 01:12 PM
Retired Member
Brian 162's Avatar
I've done it that way as a last resort when I couldn't swedge the fitting or have the correct reducer.
I have a toolbox filled with couplings elbows and reducing couplings.
It will probably work but in my opinion it looks like crap
I'm pretty ocd. If I had to see that every day I'd lose my mind
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 09-09-2023, 04:53 PM
