Jeff Hail's Avatar
6 houses later and every one was done like that. It will last longer than your teeth.
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 09-09-2023, 06:47 PM
rfuerst911sc's Avatar
I am curious why is any solder/brazing needed ? My Mitsubishi mini split in my man cave garage the copper line sets are attached via flare fittings . My previous Mitsubishi mini split at a different house was the same way . Have they changed the design ?
Old 09-10-2023, 02:52 AM
The flare connections are there but to the left - more inside.
I don't like more braze joints than necessary.
At this point I'm not too happy with the quality I'm getting.
Sold: 1989 3.2 coupe, 112k miles
Old 09-10-2023, 06:06 AM
^^^ So why aren't the copper lines one piece from the flare on the condenser to the flare on the evaporator ? I wouldn't be happy with your install either .
Old 09-10-2023, 06:29 AM
Because they brought the line set material on the first day and it was cut to length already without good checking on the dimensions needed. I just don't understand why they would do this after years and years of experience. I've worked with top quality workmanship from plumbers at the University of California. The quality comparison is dramatic. I'm guessing the pay comparison is also dramatic.
This is what I get for choosing one of the top companies around here for this sort of work.
Old 09-10-2023, 07:10 AM
Reminds me of the saying " I cut it 3 times and it's still short " 😩 . If that work is from one of the best I would hate to see lesser than work .
When I installed mine I hooked up all wires and copper lines to the inside unit . Then called the installer . He terminated everything at the outside unit . All to proper length and all to fit inside vinyl chase . To me that is the only way to do it .
I wish you well getting a clean and professional install . Good luck .
Old 09-10-2023, 07:22 AM
I had my radiator repaired at a big radiator place and the guy made it look effortless, result could have been in a museum.
That photo looks like some mess that I would make. Either they had the new guy do it or just no pride in their work.
If you're actually paying top dollar you might want to talk to their boss? The joint isn't a real problem but other shoddy work might be.
Old 09-10-2023, 11:16 AM
I rather have silver brazing for connection then flared nuts.
Again, it may not win any beauty contest, but it will work for a very long time. Plenty, I bet more then an inch of silver brazing materials in there to prevent any leaks. That if they didn't just shove it together with only 1/4" within the the larger diameter pipe
Old 09-10-2023, 11:43 AM
Zeke's Avatar
Sorry, but it's overheated even if that kind of joint is Kosher.
Comment below and don't forget to like and subscribe.
Old 09-10-2023, 03:03 PM
Well, here we are now. The system is "installed" and they are having difficulty hitting the evacuation numbers. One junior worker tried brow beating me into accepting evacuation and hold numbers that they were able to do, not following Mitsubishi spec. If anyone wants to discuss the Diamond Contractor "program" advertised by Mitsubishi I can do that. I'm not feeling it. I think it is just the state of the residential industry - do subpar work and get the customer to accept it. Of course there are professional excellent techs out there - I don't know how one finds them. I found so many mistakes at this point. Probably more I don't know of.
Old 09-23-2023, 07:22 AM
peppy's Avatar
That's a leak!
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-23-2023, 08:00 AM
Originally Posted by peppy View Post
That's a leak!
Yup. That *****ty braze is the first place I’d look
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2025 Ranger Raptor
Old 09-23-2023, 08:17 AM
The 600 psi pressure test.... sort of passed? It is hard to tell because the gauge reading goes up and down with temperature. Started at 600 and went to 592 over 12? hours. I have a graph.
At this point they need to be professional and get the guy that knows what he is doing to come on site. He is coming from Texas to CA. Longish story on that.
The "leak" is one or more of:
- instrumentation/vacuum hoses/fittings/etc.
- a "pool" of water somewhere in the line sets (haven't cracked the isolation valves)
- bad flare fitting
- bad braze joint
- could be the isolation valve(s) have a leak but this is described as unlikely
There are many classes and various videos regarding finding leaks and evacuation on YouTube. I find it interesting.
Old 09-23-2023, 08:26 AM
908/930's Avatar
This is two weeks of install, I think that company needs to send some of their installers for some proper training. Did they try checking the welds with soap with the 600psi charge? There is spray on dye penetrant test that would likely find any holes but requires no internal pressure. Did they clean and flux the new fitting prior to brazing?
Old 09-23-2023, 09:11 AM
The one person that has the proper training is the general manager. He now remotely "manages" the California workers from his home in Texas. The company is required to have one officially trained person in order to advertise being Diamond level. I asked for the trained person and that "forced" them to fly the person out from Texas. I think he comes once a month anyway.
Re. soap. You are not supposed to use soap. They have non-corrosive bubble fluid now.
I was not able to watch re. how they did the brazing.
Old 09-23-2023, 09:32 AM
FUSHIGI
This is all just a fluke. This has never happened to them before your install.
Cults require delusions.
Old 09-23-2023, 09:43 AM
I’ve seen that type of brazed joint many times over the years. Usually on distributor lines from the txv to evap coil. O.K. when it’s out of sight, but that’s just sloppy unprofessional brazing. Should have used reducers or swedgedd the lines. Silfos is normally used for connections. Brazing is a learned technique. When I worked at Carrier, I went to brazing classes to learn the proper techniques for using 45% silver. Just unprofessional sloppy rushed job in my opinion. I do my own solder work anyway.
Old 09-23-2023, 12:19 PM
How did you know the company owner would say that to me?
Old 09-23-2023, 03:52 PM
What did you expect him to say ? Yeah we do this crap all the time what's the problem ? Nope . Your expectations of a professional install are valid . Their expectation of slamming it together and getting paid are not . Hopefully the 2nd time around they do a better job .
Old 09-24-2023, 04:35 AM
UnRegistered User
billybek's Avatar
A new system should be able to hit 250 microns easily. 250 microns not rising over 500 in a 10-15 minute time period while the pump is isolated or blanked off from the circuit.
Moisture in a tight system will freeze and the vacuum level may get close to 500 microns or below but the ice will sublimate decreasing the vacuum level over the time period the pump is blanked off from the system.
What evacuation target was specified by the manufacturer?
Bill K.
Old 09-24-2023, 05:52 AM
