-   -   Help - mysterious stain on wall (http://forums.pelicanparts.com/showthread.php?t=1152336)
Paul T 12-19-2023 09:06 AM
Originally Posted by rfuerst911sc (Post 12154391)
the bees nest 😋
lol…
Shaun @ Tru6 12-19-2023 09:22 AM
Has anyone here seen the Doctor Who episode, The Lodger? It could be that.
techman1 12-19-2023 10:01 AM
HVAC change?
Running heat due to first cold spell? Thinking lotta warm air hitting a cold membrane.
A lot of rainfall?
Pressure washing windows?
Paul T 12-19-2023 10:03 AM
Originally Posted by techman1 (Post 12154454)
HVAC change?
A lot of rainfall?
Heat has been on for a bit and we keep it cool (mid 60’s). We did just have about 4” of rain with strong winds….thinking now based on responses maybe some water got in through chimney flashing.
ErVikingo 12-19-2023 10:15 AM
Originally Posted by Turbo_pro (Post 12154353)
Jethro Tull in the attic.
He was the whistler.......
Dixie 12-19-2023 12:37 PM
The bees nest 😋
Lol that explains it!
My vote is roof leak, fwiw
Steve Carlton 12-19-2023 12:53 PM
I'm taking 10:1 odds on the dead body.
908/930 12-19-2023 01:18 PM
12 year old house, the sides likely have Tyvek? Roof leak. How air tight is the house? Dryer or stove vent causing vacuum?
Bill Douglas 12-19-2023 01:27 PM
Yep, I'm with Steve on this. 12 year old house = Mob funded property development. Mob needed somewhere to dump the body.
Turbo_pro 12-19-2023 01:38 PM
"Snot running down his nose
Greasy fingers smearing shabby clothes
Hey, Aqualung"
RobFrost 12-19-2023 04:53 PM
Does the flue carry clean steam, or smoky smoke?
This is a small dribble of dirty water happening frequently in a small quantity and drying up. Given the flue nearby, assuming it carries smoke then I'd say that's creosote leaking out.
If not, then I'd say it's condensation forming in the cavity above possibly related to the flue, and washing water soluble material down the back of the pitched wood, which is entering. Definitely needs fixing else it'll rot the wood from the back out of sight.
Sent from my SM-G988B using Tapatalk
pmax 12-19-2023 05:24 PM
Originally Posted by Paul T (Post 12154296)
Thanks in advance for anything thoughts!!
http://forums.pelicanparts.com/uploa...1703002290.jpg
http://forums.pelicanparts.com/uploa...1703037758.jpg
Paul T 12-19-2023 05:46 PM
The flue is for a propane fireplace that is rarely used….hasn’t been on in several weeks.
The Synergizer 12-19-2023 05:50 PM
<iframe width="560" height="315" src="https://www.youtube.com/embed/xubDFQrAPFs?si=Q2e0__0gYCF2emCe" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
A930Rocket 12-19-2023 06:02 PM
I’m going to go with some kind of insect, rodent, etc. poop or pee. Pull the stained trim down and tell us what you see.
Paul T 12-20-2023 06:25 AM
checked it again with the moisture meter this morning and it's down several points, so seems to be drying out. I think chimney flashing is the likely culprit and this last downpour with high winds was enough for a bit of rain to get in a small gap. I'm going to have someone check it out...this chimney is very high, equivalent to 3 stories from ground in back of house, and on a steep cedar roof - my roof climbing days are over!
jhynesrockmtn 12-20-2023 07:33 AM
We had an occasional leak around our chimney 2 years ago. Seemed to only happen with the right combo of heavy rain and wind direction. It was resealed but I do need a new roof. Just putting it off as long as I can!
Noah930 12-20-2023 07:40 AM
I was thinking poltergeist. A little brighter shade of red and it could pass for blood. But yeah, putrefying juices is a possibility.
Paul T 12-20-2023 07:46 AM
Yeah, I'm thinking something similar. After posting this, I vaguely (VERY vaguely) remember something similar now a couple of years ago, where I recall wiping what I thought was soda at the time off a wall and was confused as to how it got there (we don't drink soda). It's wasn't nearly as bad as this and I didn't think much of it at the time, but now that I think about it it may have been in this very spot. So like you said, probably just the right combo of wind and rain. I'll get it checked out soon....
ckcarr 12-20-2023 09:15 AM
I had or still have a leak from my roof where the flashing was between roof and a entry gable. Under the right weather conditions, like severe rain and sideways 50 mph wind water would get in. Not sure if I solved that problem but I bought matching shingles and then covered that aluminum flashing. Unfortunately I need to do some interior repair work still as it came through the bathroom ceiling in a corner. When up in my attic I cannot see anything, but somehow it gets in. It was also in a bathroom I never go in and wasn't paying attention.
