Help - mysterious stain on wall
So, this morning I just noticed these stains on the hallway wall leading upstairs. Can’t say for certain how long they have been there but I can’t imagine more than 24 hours - I think I would have noticed this immediately. Whatever it is, is completely dry, not sticky at all - it does wipe off with water, but takes a bit of effort. Sure looks like it is emanating from the molding/wall seam but everything there is bone dry. It doesn’t smell and is not at all sticky. It’s almost like a stain. Anyone ever have anything similar?
Nothing has been recently painted or stained (12+ yrs ago), no one smokes and we don’t have kids, so I’m pretty certain it is not a spill of some sort. As a side note (perhaps related?), I did have quite a few yellow jackets in the house this past August. I probably found 5-10 per day. Could this be residue from a next? I’ve considered that, but I’ve never once heard buzzing or anything….and this wall is not really near where I’ve noticed bees in the past. The bees are frequently a nuisance late summer but I’ve never really thought they could be nesting as I figured I’d hear them. House is mostly foam insulated and there is no attic space above where this is occurring. Thanks in advance for anything thoughts!! ![]() ![]()
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2025 Ranger Raptor |
Fastrrrrrrrr!
Roof leak?
Beehive in the wall? |
Beehive is my nightmare, but I’m beginning to lean in that direction. I would have thought the substance would be sticky though? And thicker. I cleaned it up, I guess I’ll see if it reappears….very odd.
Southern Class & Sass
What's above it?
Dixie Bradenton, FL 2013 Camaro ZL1 |
I don't think my suggestion is correct, but I will throw it out there.
When I was a teen, my folks had a cabin in the woods with a woodstove. The flue pipe would emit similar stuff at times. Maybe water colored with creosote? But, I think that would smell. |
Any very old timber above the stain? It sure looks obvious that water is the vehicle.
big blue tricycle stare down the darkness and watch it fade |
That looks like the little leak we had on our roof where the flashing meets the chimney. After the water filtered its way down to where it's visible it had a similar color.
1982 911 Targa, 3.0L ROW with Webers |
Constitutional Liberal
Jethro Tull in the attic.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Bedroom. No sign of anything amiss up there
Surfactant leeching. In other words, paint additives leeching out and dripping down the wall....
https://www.sherwin-williams.com/en-us/project-center/maintenance-repair/surfactant-leaching
--------------------------------------------------------------------------- "Prayer isn't a parachute. It's a compass. It doesn't save you from the storm. It guides you through it." - Bear Grylls |
Data Farmer
Is there a bathroom, plumbing, hot water heater, or washing machine above?
Doesn't even have to be that close by. Older house, it could have travelled some distance before finding a place to drip out there. The fact that it wasn't there, suddenly appeared, and is now dry makes me think of shower drain leak of something - only pouring out water when in use. Last edited by LEAKYSEALS951; 12-19-2023 at 09:34 AM.. |
That's interesting, there is a flue in the wall adjacent to where the pic was taken. Will take a look at flashing...thanks
No water really close by. House is about 12 years old. The odd part is nothing was wet - not even a little. Whatever it is was dried hard to the surface...took some scrubbing to get off.
You might have some condensation build up affecting the older latex paint or a small leak. Lots of articles and solutions on a quick search to take care of it.
I also think it's a roof leak. the water can travel down inside the wall then when it meets a structure such as the floor and ceiling of the next level downstairs it comes out where the wall meets the ceiling. It's dry because it's not much water and evaporates quickly. the color is from the timbers in the roof structure and walls. My guess...
Thanks all for the ideas, much appreciated. I will look into the roof...I think I find that to be much preferable to bees!
Edministrator
Or maybe (probably not), a dead body in a leaky garbage bag.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Just remembered I had a moisture meter laying around that I picked up a few years ago….there is definitely some moisture there….
![]() It’s all right at that corner….if I move a couple inches in any direction I get zero. EDIT: Got readings as high as 25% in far left edge.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2025 Ranger Raptor Last edited by Paul T; 12-19-2023 at 10:36 AM.. |
