Throw it on the ground!
Jeep Wrangler overheated today. Head gasket blown or worse
2014 Wrangler with 78k miles overheated today. Engine light and coolant hot idiot light came on. Otherwise it was driving fine. Got home and checked the radiator and overflow tank thinking the level was low but found chocolate milkshake leaking from radiator cap and overflow tank obviously contaminated with oil. Dropped it off at the shop for a diagnosis. Keeping fingers crossed that it a head gasket only failure vs engine failure. Any similar experience here? Thoughts? FWIW it has never been driven off road.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
My first thought is for a car that 'young' that has had regular maintenance, it shouldn't have happened.
Scott '78 SC mit Sportomatic - Sold |
Any issues with the HVAC system in its history?
UnRegistered User
Looks like it needs a hit of Pepto-Bismol.
Good luck, hope it hasn't **** the bed...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
I'd venture a guess that it will be the oil cooler leaking.
Super common, unfortunately. His pictures are like yours. I'm trying to get motivated to repair mine, but it's not too bad yet. https://www.carparts.com/blog/bad-oil-cooler-symptoms/#:~:text=it%20off%20immediately.-,Coolant%20Leaks,even%20crack%20the%20engine%20blo ck. Here's a video on the repair. If you take to a dealer, it will be around $1,200 or so.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. Last edited by ckcarr; 05-15-2024 at 06:01 PM.. |
If youre going to repair, get the cooloing system flushed as soon as you can or all of the hoses will be damaged by the oil.
Counterclockwise?
I think fixing the problem can be done, it's the flushing of the system that will be tricky.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Grappler
My initial thought was that you may have caused more damage by continuing to drive it home after you saw both check engine and coolant light on. These lights usually don't come on until the engine is way past operating temp.
Typical rule is to immediately pull over when your car starts overheating. better to pay a towing fee than an engine rebuild fee. That year Jeep has a few issues with the cooling system but usually its just a stuck thermostat, however a stuck thermostat if not repaired can cost you an engine.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Shout laundry detergent is excellent as a flush for intermix sludge . Learned that from a renowned engine builder .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Now in 993 land ...
Would it overheat if the oil cooler went? It happened to me once, truck drove just fine. No overheating.
why does the sludge seems to come out of the window washer fluid reservoir? that yellow cap does not seem like a cap that can contain pressure en
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
pic upload failed but you see that this is a washer reservoir in the youtube from about 1 minute in.
Got a call from the shop last night. The initial assessment is that it is an oil cooler failure with no intrusion into the engine as the oil does not appear to be contaminated. Will know more after they get started with the repairs.
Now in 993 land ...
Definitely have them change the oil and give you a sample. My shop at the time didn’t change it. I changed it myself and sent it in for analysis and lo and behold, it had traces of coolant.
For me it was a warranty repair. The shop did a mediocre job. Replacing only some of the hoses and the expansion tank. Oil sludge came back and it really soured me on the truck, Even though it probably ended up being reliable. I drove it for a while while and sold it during the pandemic when prices were crazy high. |
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 06-14-2024 at 02:03 PM.. |
I wonder if it'd pay to get some Oil Eater fluid and use it to flush the system.
I can take a pic of the bottle I have out in the garage if you'd like to see what it says.
Data Farmer
I had intermixing issues on my 951 when I swapped in a new engine.
I ended up flushing the system 10-20 times, in the end just draining it, filling the system with a garden hose, drive, pray it would stay clean, watch sludge happen anyway, drain, and repeat. Fortunately, it was summer, so no antifreeze needed. Hopefully yours won't need as much as they have already cleaned it best they could. Last edited by LEAKYSEALS951; 06-14-2024 at 02:10 PM.. |
I use this stuff to clean my driveway and oil drain pans after an oil change.
I think it'd work OK in a cooling system if you're trying to get the oil out of it.
