That said: https://www.faa.gov/about/history/brief_history#origins Trust me, I am not a fan of the FAA, especially when they opine about drones, but processes and standards in aviation are penultimate especially in certified aircraft. Once again, I am willing to fly wingman on this.
1996 FJ80. |
Air Medal or two
I am all for buying a canopy if I can find one, yes it is do for an annual that's why I am scrambling.
It was born in 1957 and I have all manuals . There is a place in Ca that makes canopies for these, Bell47 and others. I am just having a real hard time locating them. Hiller says they are in business, but so far my experience with them has not been exciting.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. Last edited by afterburn 549; 05-18-2024 at 01:39 PM.. |
I hope Tim Hancock chimes in. I could be wrong. Please let me know. PM me and I'll get you my personal email. I love helicopters and want to see this work for you.
1996 FJ80. |
Still here
My other ride is a C-130J
I would consider joining the Hiller Helicopter Community page on Facebook. A lot of owners like yourself who may have leads on the parts you need.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
I think I have at least thought of using silicone caulk as a dam and peeling it off after fusing. I don't remember but I know there is no tape that will resist the solvent. I have then gone through what is essentially removing the orange peel from auto paint and polished with auto products, You know 3M is the best here. My experience is with acrylic furniture. I usually make radial stress cracks disappear. Really aggressive compounding removes a lot of sins. IIRC, no more than 1000 RPM on a circular wool pad. And even then you have to keep moving or go back to sanding. New 220 wet or dry gets this going quickly and then progress to 600. I never found the need for 1000, 1500 or 2000 grit. The cutting compound seems like 320. Cleaning the cracks before mending is a whole 'nother ball game. One last tip that I'm not too used to is to use a small flame. Again, I'm not called on to do this often so other than edge annealing a new assembly, YMMV with the heat. I've got a clear acrylic plant stand in the shop right now. I just got my Weldon. It doesn't last long even in the original container. I may try keeping this batch in the fridge or freezer. I have to research that. Doesn't work well with cyanoacrylate because of the moisture. Cyanoacrylate doesn't seem suitable for a lot of plastics. |
Vacuum forming acrylic isn’t rocket science. Sign shop can handle the dimensions
dude |
The problem of making one's own aircraft parts might turn into trouble of some sort that I would not be the one to understand. I imagine words like FAA and insurance. I believe an "inspection" was mentioned. Do these various parts not have any identification? I know it's an old aircraft.
Bland
If you could pull it back into position so it it perfectly lined up, you could put mild release on one side and make up a perfect fibreglass patch from 5 layers of 1.5 oz mat and then do the same for the other side. Them you could sandwich the cracked come between the 2 perfectly contoured glass pieces.
You are dealing with a mess there.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Zeke, Have you tried Aluminium duct tape? I have not tried it but it should work.
If afterburn 549 is allowed to repair I was going to suggest using the thicker Weld-on#16, using aluminium duct tape on each side of the crack to protect the plastic and apply a bead and cover with duct tape to buy some time and pull it through the crack with vacuum. I have used weld-on #4 but I would usually dissolve some material in it to thicken it up. Most of it was to manufacture prototype QC imaging phantoms, and sometimes repair ones that were mishandled and placed down hard and cracked. These were about $20k+ to purchase, you would think people would be careful with them. Good idea to read the MSDS, then get somebody else to do it. At very least wear goggles. I had a coworker splash his eyes with a product used to dissolve and bond nylon, fortunately there was an optometrist office near and they could quickly flush his eyes out.
87 930, Last edited by 908/930; 05-19-2024 at 12:02 PM.. |
Yes, the silver mylar tape should work but again it's the adhesive that is the consideration. I learned the hard way that common cloth duct tape does not work whatsoever with epoxy. Actually I haven't tried any tapes with Weldon-4.
Contains Methylene Chloride (same as paint stripper) and Trichloroethylene. It is a solvent, not a glue or cement, but modelers will call it cement. So in reality, not many tapes will stand up to it. But the tape is only intended to trap the flow. I would do a few tests. |
Air Medal or two
Whoa whoa!
Hooa $$$$$$ It turns out, that Walters helicopters can get these parts !! My emergency is now perhaps over? Thanks for the input and help. I might try a glue job, but if it fails to pass the test I now have an" Advance to the rear plan !" Yea!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
1996 FJ80. |
dar636
I didint see any pics of the cracks but in general helo bubble enclosures are repairable - check out section 3 on transparent plastics...
https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_43.13-1B_w-chg1.pdf |
Air Medal or two
Thank you Dar636
