Southern Class & Sass
Dixie's Avatar
DIY rug cleaning?
What's the most practical, and cost effective, way to clean my 13 x10 rug? Can I take it outside and wash it using a hose and detergent? I'm asking because my local rug cleaner wants almost as much to wash it, as it cost to buy. It's from Lowe's, and woven from polyester.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 06-11-2024, 08:00 AM
Test a small spot first to make sure the colors aren’t going to fade or run.
Try and get it to dry as quickly as possible afterwards.
I think you’ll have very good luck cleaning it yourself.
Rutager West
Old 06-11-2024, 08:10 AM
Control Group
Tobra's Avatar
Rutager has it.
You are going to want some help, that thing is going to get HEAVY when it is wet.
Old 06-11-2024, 08:53 AM
HobieMarty's Avatar
Carpet shampooer, perhaps, ya know, it puts the water and cleaning solution down and pulls it back out, heated ones work the best. Go over it a few times and keep extracting water, and it will be nearly dry by the time you are finished.
Wonka
Old 06-11-2024, 09:06 AM
Dixie's Avatar
Rutager has it.
What if I just leave it laying to dry?. I mean, aside from the rainy season beckoning.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 06-11-2024, 09:13 AM
Counterclockwise?
Maybe it just needs a good beating?
Rod
1986 Carrera
2001 996TT
In this area, Lowes, Menards, and HD rent out HD carpet cleaners for $40 for 24 hrs.
If you have carpeted rooms that need cleaning...do both at once.
I've never rented one....but heard they work well.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 06-11-2024, 09:22 AM
Dixie's Avatar
Not to be difficult, but I can't see fitting one in a Camaro.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 06-11-2024, 09:27 AM
Edministrator
Steve Carlton's Avatar
New carpet- Camaro tax. Maybe a 13x10 pool table?
If you leave it out to dry, I'd drape it over those chairs or something.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 06-11-2024, 10:29 AM
jyl jyl is online now
jyl's Avatar
Buy a Bissell carpet cleaner, around $200 and Amazon will deliver. We have a large one (for annual deep cleaning) and a small one (for spot cleaning). These are home versions of the carpet shampoo'ers that you can rent, and work well. There are limits, if you've spilled ink then don't expect it to come up, but for normal dirt and stains, you should be able to get them out or mostly out. No need to move carpet, you clean in place.
Old 06-11-2024, 11:29 AM
Counterclockwise?
I did this 20 years ago and even thought I only use it once every couple of years, I have no regrets.
Rod
1986 Carrera
2001 996TT
Old 06-11-2024, 11:41 AM
I recently bought a Bissell carpet cleaner that employs steam. They claim the only one on the market. It does work really well. I got it because I have a new puppy. Now she's house trained thank God
Old 06-11-2024, 01:54 PM
I would try and get at least some kind of spacers underneath to help speed up drying. You don’t want to get mold on it- maybe get a fan under an edge. Put a few plastic pails or bins under it randomly to allow air to circulate.
Rutager West
Old 06-11-2024, 02:15 PM
If it's polyester, then it's unlikely to change colors (unless it's just that dirty).
But still always good to test just in case.
You should be able to rent a carpet cleaner from Home Depot, and maybe Publix.
Old 06-11-2024, 02:44 PM
Old 06-11-2024, 02:48 PM
Yep, you can get them relatively inexpensively, and those work pretty well.
Old 06-11-2024, 02:49 PM
Over the years I've seen this many times. People put pails and cans and whatever under the rug or carpet to help it dry after a plumbing leak or whatever. The problem is the backing stretches over the paint can and sometimes it's impossible for me to get it flat again, even with a power stretcher. More times than I could count I've had to tell the home owner they need to buy new carpet
Old 06-11-2024, 02:50 PM
Definitely. Elevated is the way to go.
Old 06-11-2024, 02:51 PM
Interesting, and good to know. So likely what needs to support is something full length, like a long railing or something like that.
Or maybe just lay it on the roof of the camaro
Old 06-11-2024, 03:02 PM
HD rents trucks for $29 for 90 minutes.
But I’d get a couple cans foaming carpet cleaner and a brush. Drag it outside and scrub then hose. Wait till it’s dry then drag it back in. You already said it’s poly so it’s not going to curl up and die from a bit of moisture.
Old 06-11-2024, 03:17 PM
