Southern Class & Sass
DIY rug cleaning?
What's the most practical, and cost effective, way to clean my 13 x10 rug? Can I take it outside and wash it using a hose and detergent? I'm asking because my local rug cleaner wants almost as much to wash it, as it cost to buy. It's from Lowe's, and woven from polyester.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Test a small spot first to make sure the colors aren’t going to fade or run.
Try and get it to dry as quickly as possible afterwards. I think you’ll have very good luck cleaning it yourself.
Rutager West 1977 911S Targa Chocolate Brown |
Control Group
Rutager has it.
You are going to want some help, that thing is going to get HEAVY when it is wet.
She was the kindest person I ever met |
Carpet shampooer, perhaps, ya know, it puts the water and cleaning solution down and pulls it back out, heated ones work the best. Go over it a few times and keep extracting water, and it will be nearly dry by the time you are finished.
"A little nonsense now and then is relished by the wisest men." Wonka |
Counterclockwise?
Maybe it just needs a good beating?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
In this area, Lowes, Menards, and HD rent out HD carpet cleaners for $40 for 24 hrs.
If you have carpeted rooms that need cleaning...do both at once. I've never rented one....but heard they work well.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
Not to be difficult, but I can't see fitting one in a Camaro.
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 06-11-2024 at 10:31 AM.. |
Edministrator
New carpet- Camaro tax. Maybe a 13x10 pool table?
If you leave it out to dry, I'd drape it over those chairs or something.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Buy a Bissell carpet cleaner, around $200 and Amazon will deliver. We have a large one (for annual deep cleaning) and a small one (for spot cleaning). These are home versions of the carpet shampoo'ers that you can rent, and work well. There are limits, if you've spilled ink then don't expect it to come up, but for normal dirt and stains, you should be able to get them out or mostly out. No need to move carpet, you clean in place.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Counterclockwise?
I recently bought a Bissell carpet cleaner that employs steam. They claim the only one on the market. It does work really well. I got it because I have a new puppy. Now she's house trained thank God
I would try and get at least some kind of spacers underneath to help speed up drying. You don’t want to get mold on it- maybe get a fan under an edge. Put a few plastic pails or bins under it randomly to allow air to circulate.
Over the years I've seen this many times. People put pails and cans and whatever under the rug or carpet to help it dry after a plumbing leak or whatever. The problem is the backing stretches over the paint can and sometimes it's impossible for me to get it flat again, even with a power stretcher. More times than I could count I've had to tell the home owner they need to buy new carpet
Definitely. Elevated is the way to go.
Or maybe just lay it on the roof of the camaro
HD rents trucks for $29 for 90 minutes.
But I’d get a couple cans foaming carpet cleaner and a brush. Drag it outside and scrub then hose. Wait till it’s dry then drag it back in. You already said it’s poly so it’s not going to curl up and die from a bit of moisture. |
