Porsche's Six Stroke Engine
Glad to see the ICE is still being advanced.
https://www.yahoo.com/autos/porsche-dreamed-6-stroke-engine-160300596.html from the article...."The secret to making this novel ignition is a crankshaft that rotates around two concentric circles (also known as an annulus)"
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 09-18-2024 at 03:45 PM.. |
Interesting concept .
It's nice to see that they haven't given in to the "It must be Electric" mission.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
Model Citizen
Crap.
It took me a long time to be able to recite "suck-squish-bang-blow" at a moments notice. I'm not sure if I can remember 50% more words to describe the cycle.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
1 power stroke to 4 cycles
2 power strokes to 3 cycles Simple physics
1980 911 - Metzger 3.6L 2016 Cayman S |
It's interesting that the mock-up is a flat 6 turbo. There are other 6-stroke engines but they all seem to use water injection and steam.
1983 AUDI Turbo Ur quattro 1987 PORSCHE 944 turbo |
Retired, finally
No matter how I try I cannot visualize this.
And, yes, I looked at the diagram.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Banned
id rather see sleeve valve engines come back. they seem like the most obvious next ICE development.
https://www.motortrend.com/news/porsche-engine-patent-stroke-explained/ After the first power stroke the crank gearing lowers the bottom-dead-center of the piston and exposes some sleeve valves that allow a charge of fresh air in. It's compressed as normal, fuel is injected and you get another power stroke. Seems... kind of odd? I wonder what the benefits are.
1982 911SC |
^^^ Power...from the additional power stroke?
Not sure...the article is kinda vague.
White and Nerdy
It has an extra long stroke for power stroke #1 .
At the Bottom Dead Center of that extended stroke the diagram has "scavenging". I interpret that as intake and exhaust valves are opened pushing air out the exhaust and letting air in the intake.* Between turbo charging, the lower pressure of extended stroke, some spent air and fuel leaves and some fresh air comes in, and then it compresses and goes for shorter distance power stroke #2.
Shadilay. |
You do not have permissi
(thank you Tervuren)
It looks like the compression is varied by altering the height of the piston/rod/crankshaft. So instead of a single location for the lobes/balancer/rods, the entire middle of the crank moves in an elliptical? I've seen patents for mechanically lifting the piston-to-rod pin to vary piston height. Extra weight at the end. Yeah I still don't get it. -I don't get how that extra power (especially turbo kick) can be efficiently handled even to straight cut gears at high speed. -Gear teeth wear down and make noise. Small contact area. Not a good look for LeMans. -Lots of variable-compression techniques have been attempted: https://nap.nationalacademies.org/read/21744/chapter/27 -And Infinity https://www.caranddriver.com/features/g15084183/under-pressure-the-science-behind-infinitis-variable-compression-ratio-engine uses an intermediate crankshaft like the Prius https://en.wikipedia.org/wiki/Atkinson_cycle -Not applicable but worth noting. The first 'long stroke' is very efficient for lower rpms. The extra cycle is what I don't understand. The "compression-power-exhaust" sounds like the first exhaust has left but there is still pressure in the cylinder with more squash. Do they keep and use that stored exhaust pressure as another short-stroke under turbo? How does the cylinder stay clean without using hydrogen/methanol/etc?
Meanwhile other things are still happening. Last edited by john70t; 09-19-2024 at 08:40 PM.. |
Bland
Will it have sealed for life bearings in it?
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I think a 6-stroke is overly complicated but this guy explains it well as usual:
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
