2007 BMW 335XI - ECU Question
Hey, quick Q for the modern-ish Beemer guys
My friend is trying to get her 2007 BMW 335XI running. A previous "mechanic" really screwed the car up, stole her ECU and other stuff, then absconded. She bought a used ECU thinking it could be reprogrammed but her current mechanic says that is not possible, the car needs either the original ECU or a new one programmed by the dealer - and that is a $2,000 item for a car worth maybe $4000 so . . . Does this make sense?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Yep.
The ecu should be married to the immobilizer, so even with a good used ecu, it won't start. |
Is it a used ECU for a 2007 335xi? If it is for the correct car a local BMW indy or a tuning shop should be able to plug in and sort that out.
87 930, |
It is indeed a used ECU for 2007 335xi
I’m thinking maybe you need BMW-specific software and her current mechanic, who is just a local guy with no BMW specialization, doesn’t have it.
Navin Johnson
ECU Doctors
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Tru6 Restoration & Design |
If the car is in the Portland area, give these guys a call.
https://www.munichmotorworks.com/ The owner, Joseph is a pretty stand up guy. I used to use INPA for my 2001 bmw, but I don't know if it works with a 2007. |
I belong to an Autel forum , and I have seen , where people have indeed replaced, and reprogrammed used ECM's and Modules with their MAXI Sys, on BMW cars
The factory software/system for BMW is called ISTA P. It may , or may not program used ECM's, but there are guys out there smart enough to do it with aftermarket scanners I have the equipment to do it, but have never tried a used ECM on a bimmer. I have pulled it off on a GM truck, and a Honda before . This is definitely not my wheelhouse, but I usually muddle my way through it when I have to . Good luck
No left turn un stoned |
Do a search on Bimmerforms, etc. Last edited by A930Rocket; 10-04-2024 at 07:11 PM.. |
