Cigarette lighter battery charger
Hi,
Can anyone recommend a good battery charger that I can plug into car lighter? Thanks. |
Is your 12V cigarette lighter plug hot with the key off? Not all of them are. If so, all of the low amps charger/maintainers would work. Some come with the needed plug in, some don't, but a little wiring work & a male plug in...bingo.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Thanks. I’ll take a look tomorrow if I get home early. It’s a 986 boxster.
You can buy an accessory for the CTK ones for that. I have one, but I prefer to add the wire with a connector at the battery to my cars. It is easier to use than messing around inside the car to plug it into the lighter.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
I took my bumper off the car on Sunday to clean condensers and radiators. When putting the plastic trim that covers the area where the latch is, I dropped a plastic tab lock (there are 4 of them). Anyhow, I was able to open trunk but then a day later when I went to put a new plastic piece in, the trunk wouldn’t open. It makes noise but won’t unlatch. Not sure if mechanism is just bad or if I screwed up dropping the plastic piece. Unfortunately I can’t open hood at the moment and I don’t have time to try to remove wheel liner and fish out emergency cable. Hopefully it’s where it suppose to be or this will get real expensive.
Thread Tools | |
Rate This Thread | |
