Plasti Dip
Anyone use on something other than rims? I like to use before I actually paint but have only used on rims. Would it work on a painted front window frame and would removal be a problem. On rims it’s easy to remove.
Thanks. |
I used plastic-dip on the fender and running boards of my Jeep TJ. The coating lasted maybe a couple of years? I know a few guys who’ve used it on window trim over chrome. Didn’t look bad at all and probably wouldn’t be hard to chip off if necessary.
Platinum Member
https://www.santacruzforums.com/threads/plasti-dipd-the-grill.13290/
I'm planning on doing my grill.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
It'll be legen-waitforit
I got it done on plastic trim in my Cayman frunk. Did a carbon fibre look turned out really well. Hydro dip though not the spray on kind
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Thought plastidip was the liquid rubber stuff you could put tool handles etc in to rubber coat them?
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
I am planning on doing my wheels on my craptastic F250. Any tips and insights are welcome.
Cars and Cappuccino
If you use tape to block off the tires fromm the rims remove it while the Plastidip is still wet.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Wooden rake handles.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Based on mostly wheels and some trim pieces, I'd say yes but depends how thick... The thicker, the easier to take it off... Thin coats are a $%$#%$#% to remove, in that case you'll be using chemicals and elbow grease. Thick coats, cake, even oddly satisfying. Window frame, I would try - small risk.
Counterclockwise?
I used it on the chrome emblems on my Tundra and it looks real nice.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Used it on the door handles of my 350Z. Actually lasted quite a few years but when I removed it, it took some of the original "chrome" finish off, as well. There was clearly a chemical reaction there as the chrome was pretty thoroughly bubbled. Ended up having to replace the handles.
Guy '87 944 (first porsche/project car) |
Banned
i plasti dipped my ice racing front bumper, and i gotta say, its holding up way better than i expected it to.
