I too am just a wood butcher, not a carpenter. I can make some basic stuff, but it sure ain't work I would accept if I was paying for it.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I see you
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
I see you
+1
weekend wOrrier
this thread gives me wood... (wood magazine)
https://www.woodmagazine.com/project-plans/workshop-jig/jigs-fixtures/zero-clearance-cutoff-guide-downloadable-plan This one's fancy, but simple. I couldn't cut a straight line for the life of me. Usually just find a straight board and clamp it over whatever I'm cutting as a guide. Makes the cut piece more stable too.
100% narcissist Last edited by LEAKYSEALS951; 10-07-2025 at 03:38 AM.. |
My brother worked as a carpenter, and even a trim carpenter doing crown moldings in Antebellum mansion restorations. He can use an old skill saw and cut a straight line and it looks like a table saw cut. He also likes to camp in the woods.
I did not get those skills and my idea of camping is a hotel with no TV or internet. He still struggles with his cell phone, and does not use a computer. I took to computers in the 80s, and it became a large part of my profession.
I think like anything else, its just " seat time " If you are really trying, the more you do , the more you will find ways to improve and up your technique etc.
Hack carpenter here .. I really appreciate the skills when i work with someone who is good at what they do . I always pay attention
No left turn un stoned |
gduke2010
I’ve been a carpenter for 30 years. Ask me to do plumbing, no way. I suck.
+1 on the worm drive. Mine is an older Skil 77, no issues with straight cuts. I think it is the added weight and balance.
Well, at least you're building something. You might get a C on execution, but you get an A for trying.
BTW "I can't," should be, "I can't yet."
I'm guessing the Worm-drive vs direct drive difference is like the difference in trying to turn a 17' Cadillac from the trunk vs turning a mid-engined 914.
The handle for the worm drive is 1) way out back (looks like 4-6" back from the rear edge of the blade). 2) a tiny change in your wrist shouldn't make much difference in the direction of cut. It would require a much larger change which should be much easier to feel. But I think the worm drive is also quite a bit heavier which is not great for you. The handle for the sidewinder/direct drive saw is practically behind the blade when looking at the saw from the side. So a tiny twist of your wrist can amount to a big change in the angle of the blade. worm drive ![]() sidewinder ![]() That that all means to me is that you/I/a bunch of us, need a guide of some sort to keep us on the straight and narrow. Semi-related automotive story. I sold my old '88 911 where you sit pretty central to the vehicle. So when the car turns, you feel like you're turning with it. I then bought a Mazda Miata. Sitting in the driver's seat with the door open, I could stick my arm out and touch the rear tire. When you're sitting in the car, especially me with the seat nearly all of the way back, you feel like you're sitting on the rear axle. If you look in this pic, the side-view mirror looks like it's pretty close to the middle of the car. When I first started driving a miata, it felt "weird" because when you'd turn the car, it felt (to me) like I was being swung around behind the car which was a result, I think, of my seating position being farther rearward from the center of rotation of the car vs the 911 where it felt like you were nearly at or much closer to the center of rotation. ![]()
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() Last edited by masraum; 10-07-2025 at 11:25 AM.. |
Navin Johnson
I have at Kreg guide for ripping... it wasn't to much coin, and has a plate that fits to my DeWalt circ saw and follows the guide..
Festool is to much for my skill level
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I assume you like your Kreg. You didn't say "it sucks" so it must be at least decent.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Clamp a straight edge to your stock to make a fence. Your sidewinder or worm drive will cut as straight as a table saw
Navin Johnson
I've used it to make multiple passes on 2.5" black walnut used for an epoxy table,, and you can barely tell the saw passed 3-4 times.. accurately repeating a cut is a +
It seems that the kreg straight edge guide is well loved and quite a bit cheaper than their accucut. It's available in 4' or 8'
https://a.co/d/eRGqHYN |
Parrothead member
This is my baby, my main workhorse. Has to be around 25yrs old. It's a beast. Still cranking. Did a brush change on it a few years ago.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I saw this on FB yesterday (and 50 others similar), but here's the YT version. (I probably wouldn't just use CA glue, but that's just me)
One of the key bits is that the stop that holds the jig square is (like in the video above) cut off by the saw itself so that the cut edge is also a guide of exactly where the blade will be cutting so you can line up your cut-line with the edge of that stop. I've seen several variations. I saw one that was basically just a T-square where the long bit was a wide-ish (looked like 4" wide) plywood (more dimensionally stable) connected with 4 screws. That version is probably best for long rip cuts that are 4' or longer. For the models with the triangle, I assume those would be built smallish (less than 12" or maybe 16" for crosscut). I saw a few where the triangular bit was an isosceles triangle so that the jig can be use for 90º or 45º cuts which is convenient. I saw some where the triangle was cut from one piece of plywood which probably adds more rigidity and makes it easier to build. One of the nice changes that I saw had the base of the triangle where the stop was cut with a slot that you could put a quick clamp in to hold the guide for you (something like this) ![]() I saw one similar where the saw was set at 45º so it could be used for bevel cuts which is cool, but something that I hardly ever do. I saw some fancier versions where the triangle was adjustable which is great, but I like the fixed, guaranteed square cut from a non-adjustable version. I also saw one or two where the thing was made like a track saw, one long piece of plywood with a narrow fence attached where the edge of the plywood was cutoff by the circular saw which allows the saw to slide on the jig, and the bottom of the jig supports the top of the wood being cut for a cleaner edge, especially on plywood. Of course, I don't think that any of these would help if you'd built a deck, and needed to cut all of the ends of the deck boards straight after the fact. But they would help with many/most other crosscuts or long rip cuts.
Stuff happens. Carpentry is an art and for those of us who don't do it every day, a speed square and a worm saw make it look like we actually sorta know stuff. My cuts will never be laser straight but... straight enough to make decent joints that will stand the test of time.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Thread Tools | |
Rate This Thread | |
