FUSHIGI
CAFO side effect
In the past 6 months, there has been a marked increase in CAFO (concentrated animal feeding operation) liquid manure tractor/tank trains consisting of up to 10 rigs driving in the dark holding up 15 cars on different highways. Recently an 18 wheeler rear-ended one and the driver died on the scene. Where is the tipping point on this stuff?
Cults require delusions. |
Kantry Member
Not sure of your question. Are you asking where do they dump for processing or when the system will be changed so processing happens closer to the point of origin?
Somebody has figured out how to make a buck on processing or spreading or dehydrating large quantities of the material. The best solution for the traveling public would be a digester at the point of origin which produced methane, which could fuel equipment on site. Then the reduced sludge could be used as fertilizer to grow animal feed.
Best Les My train of thought has been replaced by a bumper car. |
FUSHIGI
CAFOs are growing in numbers. Unless directly invovled, it was mostly a water contamination issue for the general public. Now it's becoming a traffic hazard and I'd imagine it's also going to become an issue for road wear and tear issue. Not sure if these behemoths are running road tax free fuel but would imagine so. I'm quickly becoming more "interested" in CAFOs and would agree that a digester might help significantly. I wonder who makes those things as it might be a wise investment consideration.
You don't say where you are, but I have noticed the local slaughterhouses have wider distribution of the carcass manure. It used to get spread on a few local fields (possibly owned by the processor) and the remainder went through the rendering plant and water treatment.
Now more is going to farms as far as 15 miles away. Apparently there was some kind of ruling that loosened the farmers hands for spreading the stuff. (Note, this started while Biden was in office). You know when you smell it - the stink is pretty bad. Maybe unrelated to your issue, but if the plant can give it away to a farmer, it saves them money on water treatment.
1981 911 SC 2013 Mini Cooper JCW 2017 GMC K1500 |
FUSHIGI
I live in a pretty rural part of Wisconsin. Plenty of now bare crop land and it has been a bit dry so probably an optimal time to spread. Have never seen the trains of 8-10 rigs before this year.
Brew Master
I don't get it. Are they doing something illegal? Why on earth would an 18 wheeler rear end one of the rigs you're talking about? And why does driving in the dark make any difference? There's manure management. These CAFO's have strict regulation on manure management.
Nick |
I’ve never heard of it and I’ve never seen it. 🤷🏽
FUSHIGI
Maybe we could ask the semi driver how it happened--but he's dead now--Killed at an intersection after rear-ending a tractor-tank rig.
Sounds like a localized situation. I am aware that there is a global fertilizer shortage due to the ongoing Russia Ukraine conflict and so perhaps farmers are preparing their fields now with organic fertilizer. It takes time for this stuff to break down and become useful for crops and just before winter is probably a good time to turn it into the soil.
Here in Idaho we are surrounded by farming, dairies, and ranching. I know that many of the local farms are using organic (steer manure) fertilizer turned into the soil. We have seen no truck trains of the stuff though.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
FUSHIGI
(the shotguns)
Problem with CAFO's as I understand it in our area is foreign ownership. As with all markets the consolidation of sellers brings nothing good to the consumer.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
FUSHIGI
examples of the tank trailers
https://www.tractorhouse.com/listings/houle-manure-spreaders-manure-handling-for-sale-in-iowa/?Category=300028&Manufacturer=HOULE&State=IOWA
Brew Master
Nick |
Brew Master
The very large, farm version, of a "Honey Wagon". You should see one during the day spraying manure. "Purple rain"? I think not.
Nick |
