I have religiously emptied the tank on my snowblower and ran it dry at the end of every season and have had zero problems.
I will add that I use non-ethanol fuel and because it is a smallish paddle type snowblower, I can tip it on its side and pour the gas back in the can and then run it dry.
On a big blower, you could probably try and predict the amount of fuel needed on the last few snows so there isn’t much in there and then run it dry.
Rutager West
Old 12-15-2025, 03:03 PM
In the 20 some years that I've had mine...it's always started up good on the first start of the season.
It has electric start and I just plug it in for the first start and it spins the motor a lot faster than I can pull start it. After the first start, I use the pull cord for the rest of the season.
I will start using rec-gas from now on.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 12-15-2025, 03:24 PM
Counterclockwise?
Originally Posted by Cajundaddy View Post
Should be easy enough to add a shutoff to the fuel line between tank and carb just like a motorcycle. Running the carb dry is the secret sauce with ethanol blend gas these days.
I did that every day after mowing the lawn with my Honda mower and it kept all the carb jets clean.
I wanted to this to my snowblower but the line from the tank to the carb is 2" long.
Rod
1986 Carrera
2001 996TT
Old 12-16-2025, 06:31 AM
98 Honda Prelude
22 Honda Civic SI
Old 12-16-2025, 01:43 PM
I didnt read everything but you said its a tecumseh if it has a thumb screw on the float bowl you can usually tickle it turn it in and out a 1/4 turn or so and see if it improves. Out gives more fuel. If that doesnt work or if it has none then you can tip it up on the front remove the bowl and clean it out. You dont need to remove the carb.
Old 12-16-2025, 03:14 PM
^^^ I was looking today at the underside of the Tecumseh for a place to add a shut-off valve.
There is a thumb screw...I noticed a spring atop a screw on the side of the bowl.
I'll try that. Thanks.
I added the Techron and with the True-Fuel it was running very good. The only time it was surging was at wot.
I needed to get to my tool shed across the yard with my JD tractor (100 ft)....so I used the snowblower to make a path across the yard about 6ft wide. It did the job, just like new.
98 Honda Prelude
22 Honda Civic SI
Old 12-16-2025, 03:40 PM
Navin Johnson
TimT's Avatar
Just add some fuel line... I've done it on pressure washers, mowers, and you can add enough to make it easy to drain into a convenient container
'69 911 GT-5
'75 914 GT-3
and others
Old 12-16-2025, 05:21 PM
Counterclockwise?
It goes straight down. A longer hose would kink at the tank and the carb. Trust me, I tried.
Rod
1986 Carrera
2001 996TT
Old 12-17-2025, 06:48 AM
Super Moderator
cstreit's Avatar
Redline SI-1
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-21-2025, 09:59 PM
Originally Posted by cstreit View Post
Redline SI-1
I'm currently running Techron on this tank of non ethanol....it seems to be working.
If a couple tank fulls don't change, I'll try Redline...I've heard others mention that too.
If neither clears it up....this procedure has a few videos. Looks easy. (same engine as mine)
98 Honda Prelude
22 Honda Civic SI
Old 12-22-2025, 07:05 AM
That is the idle jet on the older carbs they are adjustable
Old 12-22-2025, 03:14 PM
^^^ In the video (post 50) he shows it as just tightened in....not adjustable.
But he does show it clean when he takes it out...and then later mentions that he cleaned it and then put it back in for the video.
98 Honda Prelude
22 Honda Civic SI
Old 12-22-2025, 03:19 PM
