| DonDavis |
01-15-2026 10:03 AM |
Originally Posted by DonDavis
(Post 12593477)
...Is there anything in a manual that can cause my slippage? Am I looking at a bad transmission?
The original transmission had severe main bearing wear and upon decel it made a huge "womp womp womp" sound. Instead of repairing/rebuilding that trans, I sourced a very good 1998 parts car with 125,000 miles. I transferred the trans/rear diff about 30,000 miles ago. The axles have roll pins through the splines. I'll jack it up and do what 908/930 recommends.
Originally Posted by 908/930
(Post 12593818)
I do not think it is the transfer case clutch, pretty sure that is only attached to the front drive on that car with the drive to the rear wheels being straight through. I'm still thinking rear half shaft, or somebody tried to steal the catalytic converter and attached the rope to the driveshaft by mistake and it is gone.
Driveshaft and the rear axles are still there.
Here's what mine looks like. That's where the front axles get pinned in.
Can anything in there fail causing the slipping? I've driven the car like it is for at least 50 miles, 30 of that was on the freeway at 65mph with no odd sounds or vibrations.
Strangest symptom is the MPH following the RPM when slipping with no change in actual speed.
http://forums.pelicanparts.com/uploa...1768499816.jpg
