Water softener
I just moved into my new house last week. Last night the water softener made a very loud horrible noise for about 10 min. When it stopped it showed a count down from 300 to 1. Seems fine right now. I know nothing about water softeners. What was that noise? Could it be because it's low on salt? I would call the manufacture but they don't open for another 4hrs. Should I disconnect it until I speak to the manufacturer?
1984 Carrera |
Friend of Warren
Sounds, literally, like the water softener was regenerating. They way they work is one cell of the tank has millions of polymer ball that contaminants in the water cling to, like calcium that make the water hard. The softener is programed (generally at night) to flush a salt water solution through that tank to flush the contaminants off the balls. The process is called regeneration and if you have a digital water softener it will tell you that is what is happening. That is probably what you were hearing.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks Kurt. I hope thats all it was. How often do water softeners normally run the regenerating process? Ounce a week?
1984 Carrera Last edited by Meka; 08-10-2005 at 06:20 AM.. |
Mine is set to cycle every 24 hours....
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Friend of Warren
Peter '79 930, Odyssey kid carrier, Prius sacrificial lamb Missing 997.1 GT3 RSnil carborundum illegitimi |
Yep. If the softener has a digital screen and soft touch buttons, you can usually navigate through the menus, and set a new regenerate time. I think mine is set to run about 3a.m.
Jack 86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi 83 Porsche 944 - Still under re-construction. 08 Suzuki Boulevard M109R LE 02 Nissan Altima SE3.5 |
