Cars & Coffee Killer
legion's Avatar
Towing
I'm headed down to Tennessee next month to start cleaning out my father's storage space. It appears the most economical way to move stuff from Tennessee to my house is going to be to pull a trailer with my F150.
I have the 4.2 V6, and it has a factory towing package. There is the flat four-pronged connector for the lights and a round connector that I assume is for trailer brakes.
I've pulled a trailer once in my life, and it was a 400 lb. painting trailer when I was a house painter in college.
I'm looking at renting the following trailer:
http://www.uhaul.com/guide/?equipment=trailer6x12
This trailer has a maximum loaded weight of 4400 lbs., and if I read my owner's manual correctly, my truck can tow up to 4500 lbs.
My questions are:
What equipment do I need? All I can think of is a hitch ball, a ball mount, and chains.
How do I determine what size drop I need on the ball mount?
Any hints, tips, recommendations?
5 liters of VVT fury now
-Chris
Old 02-22-2006, 06:18 AM
id10t's Avatar
UHaul can be picky about what they allow you to tow their trailers wiht. I've read on 356talk that several times people were forced to rent a uhaul truck to tow a uhaul trailer.
Old 02-22-2006, 06:32 AM
legion's Avatar
I was going to swing by a U-Haul this weekend (I'm not going down to Tennesse until the middle of March) to see if I could sort that all out ahead of time. I haven't thrown out the idea of buying a trailer, but it would be significantly cheaper to rent.
-Chris
Old 02-22-2006, 06:38 AM
I'm off the hook.....
U-Haul is actually the best place to have a trailer hitch installed. I know you already have one, but go to them, and let them finish what you have. That way you know there wiill be no problems come rental time. Find one of the centers that does the hitch installs, not the storefront / service station place.
No, I don't sing. Based there for too long.
Old 02-22-2006, 07:15 AM
Unconstitutional Patriot
turbo6bar's Avatar
The U-Haul place should be able to give you the information you need. That trailer looks like it has a low to medium height coupler, so I'm guessing you will probably need a drop of 1-2", assuming you have a 2WD F150.
Old 02-22-2006, 07:20 AM
Parrothead member
VINMAN's Avatar
Legion, you will have no problem at all towing that.
Vinny
Super Moderator
cstreit's Avatar
You'll need some facitlity for braking. I wouldn't want to haul that thing down in a hurry without trailer brakes! Electronic brakes will require a brake controller box installed. $55 plus installation cost.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-22-2006, 07:23 AM
turbo6bar's Avatar
Do hydraulic surge brakes require a brake controller, though? I have no idea. I just run electric drum brakes.
How many pounds of cargo, legion?
Old 02-22-2006, 07:30 AM
Parrothead member
VINMAN's Avatar
U haul trailer all have surge brakes
Vinny
Old 02-22-2006, 07:31 AM
vash's Avatar
i am a ******* when it comes to towing. i almost died once. (now i am a big fan of overkill.) if i had to do what you need to do, i would call penske and rent a moving van. i bet the cost arent that high when you consider, how much easier it will be. no backing up a trailer for a newb, less wear and tear on your 6 banger, etc.
having said that, i do see some people doing some amazing towing with what i consider a small truck. good luck.
poof! gone
Old 02-22-2006, 07:32 AM
Re: Towing
Originally posted by legion
My questions are:
Per the Uhal site:
Your towing vehicle:
* Must be equipped with a hard top if it is an SUV. U-Haul does not allow any type of sport-utility vehicle not equipped with a hard top to tow U-Haul equipment.
* Must weigh at least 3,500 lbs. (curb weight)
* Must have Class 2 tow hitch (3,500 lb. minimum weight-carrying rating)
* Must have 1-7/8", 2" or 2-1/8" hitch ball (3,500 lbs. minimum)
* Must not exceed maximum allowable hitch ball height 25"
* Must have external mirrors on both sides
* Must have fully operational lighting
* Trailer lighting must be operational at all times, day and night
* Maximum recommended speed is 45 MPH
Correct on the round plug as the electronic brake controller. However, Ford did not supply the electronic controler in the vehecile until 2004/05. You need to purchase one. It plugs in under the dash on the driver's side.
You will have no probelm towing with the 6 banger. Although I have the 5.4l, I've towed 40' trailers with my F150, lifted, 35" tires and stock gears.
That';s the same trailer I have reserved for my move to Florida, but I changed out the R&P for the long drive.
Good luck.
Old 02-22-2006, 07:37 AM
legion's Avatar
Thanks for the replies everyone!
-Chris
Old 02-22-2006, 09:16 AM
legion's Avatar
I just read the whole Uhaul flyer. It says repeatedly that I should not exceed 45 mph when towing even the heavy 6' x 12' dual-axle trailer.
It takes 7 hours to drive from Nashville to here doing 70 mph. I was thinking that 60-65 would be safe trailer speeds until I read that. Is that statement extreme over-caution, or should I really do 45 mph the whole way on the interstate, making the trip take 11 hours?
Heck, I've been passed by people towing trailers doing 85-90 mph.
-Chris
Old 02-22-2006, 11:11 AM
Eric 951's Avatar
The 45 MPH limit is to cover themselves in the event of an accident. Depending upon how heavy the load, you can do the speed limit while towing (or more). Just be aware of how a trailer affects the driving characteristics of your truck--and be sure to load the trailer evenly--don't put too much weight near the tongue, or behind the axels. Even distribution.
Eric
83 911SC/83 944
bunch of Honda 750s
Old 02-22-2006, 11:17 AM
Parrothead member
VINMAN's Avatar
I routinely tow my 32' 10,000 boat at 75mph but I also have my trailer balanced perfectly. And my truck is heavy.
There are alot of variables to consider when towing. The weight placement on your trailer, brakes on it, brakes on your tow vehicle, weight of tow vehicle, experience, etc.... It's real easy to have a trailer go out of control on you. Ive towed the boat with my Bronco, and my old f150 ( Very, very short moves) both have electric brake set up, but it still was a ***** to stop. 6x12 is not a huge trailer, it just takes loading it properly and getting the feel of it.
Vinny
Old 02-22-2006, 11:22 AM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
I towed that trailer from CA to MI with my Subaru Outback Sport, trailer was as long as my entire car. You'll be fine.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 02-22-2006, 01:42 PM
Kantry Member
oldE's Avatar
Legion,
I have no trouble with my 4.2 5-speed pulling my wife's horses. Up over the mountain is usually 3 rd gear for the most part and, with the horses we usually don't get over 55mph. (don't want to have to brake suddenly & break legs or anything.) If you have the factory 'trailer wiring' package, it is likely you also have a transmission oil cooler.
"There is the flat four-pronged connector for the lights and a round connector that I assume is for trailer brakes."
You might have two kinds of connectors, there. One the flat 4-pin, for small trailers with no brakes, the other round with 6 or 7 pins for larger trailers with brakes. The hitch place can straighten you out on them.
Make sure you have about 500 lbs of the weight on the tongue when you are towing. You should get along OK.
Now, backing up should be fun the first time you try. Can I come & watch? (Sorry, that wasn't nice. Sorry you have to make this trip.)
Good luck.
Les
Best
Les
Old 02-22-2006, 01:50 PM
Crusty Conservative
silverc4s's Avatar
In my view, driving the speed limit is okay, as long as you keep WELL BACK from the vehicles in front of you, take due caution of weather conditions, and are always aware of traffic entering the roadway you are on.
You stopping AND manuevering ability will be much worse than you are accustomed to. Don't ask me how I know...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 02-22-2006, 01:58 PM
Team California
speeder's Avatar
On recent cross-country drives I have seen 2 different accidents where someone was towing a large trailer and it whipped or rolled on them, taking the tow vehicle in a barrel roll with it. One of the cases might have involved strong cross winds, not sure. Both tow vehicles were large GM pickup trucks, (one was a Suburban), I can just imagine how terrifying that experience must have been. Shorts cleaning time.
Both were on the interstate and the people towing were amateurs, (like me), it really gave me pause. Be careful and take your time.
Denis
For the Epsteinth time, the National Guard troops are just a distraction. The only crime wave in DC is the felon in the WH.
Old 02-22-2006, 03:43 PM
Does nayone know is a LEO would, or could, cite you for driving over the 45 mph marked on the trailer?
Old 02-22-2006, 04:35 PM
