I'm with Bill
Jims5543's Avatar
Brake bleeding woas..
I helped my bro in law drop in a new brake booster and master cylinder.
I bench bled the cylinder and then bled it again while attaching the lines.
I went to the right rear and began to use my suction pump to bleed out the remaining air.
I could not draw anything from the line. I made sure the valve was open and even had him pump the pedal while I bled it 2 man style. Fluid would not run.
I moved around the car getting very little with either method.
I went to the front right and tried it. WE could barely get anything out either with the pump and hold 2 man style or with my suction pump.
What am I missing??? I have never had this happen before and have swapped more MC than I can count.
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 03-28-2006, 07:29 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Anti-locks?
You may have to have the pump on.
That's the only thing I can think of....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 03-28-2006, 08:20 PM
JW Apostate
trekkor's Avatar
I like "Speed Bleeders"
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 03-28-2006, 10:35 PM
djmcmath's Avatar
Would this be better served in the tech forum? You're more likely to get "Bush hates anti-lock brakes" here in OT.
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 03-29-2006, 03:20 AM
I'm with Bill
Jims5543's Avatar
Originally posted by dhoward
Anti-locks?
It does have rear anti lock. I thought of that too. I tried this with the engine running too. Nothing different.
We ran down to the Auto parts store to pick up some speed bleeders and they didn't have any left.
2005 Mini Cooper S
Old 03-29-2006, 04:50 AM
Eric 951's Avatar
type of vehicle?
Could be proportioning valve. Or a kinked/crushed hard line.
Eric
83 911SC/83 944
bunch of Honda 750s
Old 03-29-2006, 04:58 AM
Banned
you have cloged up bleeders.
Try takeing the bleeder all the way out and see wat hapens.
Old 03-29-2006, 05:02 AM
dhoward's Avatar
What he said.
Dan
1969 911T (sold)
2008 FXDL
Old 03-29-2006, 06:57 AM
I'm with Bill
Jims5543's Avatar
I pulled the bleeders and tried bleeding with only my finger over the hole and a rag to catch the fluid.
It ended up being the rebuilt MC was bad. We put the old one in which was fine and everything worked great. Bled it in minutes. Speed bleeders rock.
We replaced the MC because we figured it would be preventative maint. We were really replacing the Brake Booster. So get this, it is bad too.
Both parts we bought from NAPA were bad out of the box.
Before I pull it apart again I am having my mechanic look at it.
We found a bad vacume leak on the engine that was probably contributing to the brake booster problem. I am going to heve him hook a vacume guage up to it and then look over our work.
I have never had a car stump me like this, its really pissing me off.
2005 Mini Cooper S
Old 04-01-2006, 09:40 AM
