addictionMS's Avatar
Trailer Tire Question
I picked up a Zieman car trailer, it is a open bed style one (no center section so lighter weight) and I am going to replace all the tires on it. It has alumimum rims, and 225/65/15 tires on it. They look like radial car or truck tires, the only other marking is the rating "H" on them.
On my old trailer, I always put trailer tires, but this size does not seem to be available in a trailer tire. So I have the quesiton...
Can you put car/truck tires on a trailer?
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 05-30-2006, 02:04 PM
Do not put passenger tires on a trailer because of the load rating. Tire Rack has some good info. Look for Goodyear Marathon. When in doubt increase the load rating.
Old 05-30-2006, 02:16 PM
except the Goodyear Marathon does not come in the right size. Plus load rating is not much of an issue, it will be carrying the trailer and a 2200 lb car, on a double axel trailer, so the loading is minimal I would think.
jim
Jim Hamilton
Old 05-30-2006, 02:23 PM
Unconstitutional Patriot
turbo6bar's Avatar
Yes, as long as you understand they are not rated for higher loads and heat levels.
Old 05-30-2006, 02:24 PM
