Banned
MYT™ (Massive Yet Tiny) Engine
I'm not an engineer, so I thought I would toss this one out there and let you all chew it up.
Link: http://www.angellabsllc.com/ I found out about this here: http://groups.google.com/group/alt.rec.hovercraft/browse_frm/thread/1043a58adde8438d/dd2dbe12a3e8bee5?lnk=raot&hl=en#dd2dbe12a3e8bee5 Quote:
Another interesting engine. http://www.quasiturbine.com/ Last edited by kach22i; 05-31-2006 at 10:06 AM.. |
Cars & Coffee Killer
Interesting. Watching the animation really explained everything to me. It seems that there are two sets of "paddles" that form each combustion chamber. The housing is round (rather than elliptical in a rotary or quasiturbine engine). Each set of paddles is loosley coupled with the crankshaft--they can push it but also have slack not move while the crankshaft is moving.
The only thing I don't understand is what keeps the slack set of paddles from moving forward during the compression stroke?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Targa, Panamera Turbo
Lots of contact points, gonna need a good oil - might even need to explore gear oil technology combind with engine oil technology! Looks pretty cool.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
(And never having to worry about bent valves again.)
Gon fix it with me hammer
all this engine tech suddenly popping up
we had the 6 stroke head then there was that engine that used a different type of crank system now this i guess the oil prices are starting to bug people everywhere , i mean really bug em... why don't the big engine companies take these things up for big R&D and proper testing. ?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
25:1 compression ratio. And it's a dry sump. Sounds like a race engine candidate to me...
Looks like a 4 lobe Wankel to me - maybe a cross between a Scotch Yoke and a Wankel, then again I'm not a mech eng. One thing that I see right off the bat is the lubrication issues. The wipe is gonna spell trouble. Maybe they could go with ceramics or something.
Wouldn't the efficency be questionable due to the high air exhaust temp presenting right to the intake? (at least thats what it looks like would happen in the pic). Looks like pre-detonation will be a bugger. I think some after coolers would be needed no? As for use as a Stirling, doesn't a Stirling have a 10-20X displacement stroke compared to its power stroke? That doesn't look right. Again, I'm no mech eng so educate me please.
canna change law physics
25:1 will produce unacceptable emmisions. NOx will be outta site.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Honestly, I can't picture how this would work.
..and if it works, how it won't melt. There seems to be no way to cool it. Of course maybe some water injection/steam cooling ala the Crower Six Stroke would work. http://www.autoweek.com/apps/pbcs.dll/article?AID=/20060227/FREE/302270007/1023/THISWEEKSISSUE
1967 R50/2 |
I'm with Bill
I do not think cooling will be too much of an issue. We solved a lot of our apex seal problems by ditching the factory seal lubrication system and simply premixing the gas like a 2 stroke. The lubricants in the fuel keep the cylinder or housing walls lubricated remarkably well. When comparing a Rotary using the factory oil pump system, (which pumps a tiny bit of oil through a pin hole in the housing) to a premixed engine the wear on the housing walls was non-existant on the premix and the wear on the factory oiled housings was very obvious. These guys are on to a good thing here. I wonder if it will be very efficient though. One of the huge drawbacks to a rotary is the lack of fuel efficiency. A regular piston engine can tolerate a leaner condition than a rotary, the roatary relies on the fuel for cooling and lubrications so more is needed.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
B58/732
So basically this thing has 1/6 the mass of a reciprocating motor but will require 6 times its own weight in emissions control devices!
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
I would also guess that the bearing that holds the disk thats compress together would not last long due to the opposing forces applied to them. |
Hey, a 150lb engine that needs 300lb of emissions equipment, but generates 3000hp... Perfect for SUVs.
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
Re: MYT™ (Massive Yet Tiny) Engine
That angellabs engine looks surprisingly like one from an outfit called RotoBlock. http://www.rotoblock.com/ Some differences though.
Phil 1978 911 SC |
OK...the animation on the rotoblock site made it much clearer. Still, by constantly reversing the motion of the piston aren't you wasting a great deal of energy?
It seems to me that this is a more logical solution: http://www.roundengine.com/ Piston constantly moving in one direction with a constant torque arm.
1967 R50/2 |
i think bicycles are cool...
1967 R50/2 |
