what’s the difference in 2-stroke oil?
Ok.. so oil isn’t just oil…
But I was advised that I cannot use STIHL brand, or any two stroke oil designed for small engines in my two stroke Suzuki 150hp outboard.. Why is this? What is different about the oil? Both 2-stroke vs 4-stroke and “2 –stroke outboard” oil vs regular 2 stroke im just curious.... -Nick
SWB |
don't know but castrol A747 is the gold standard for 250 GP racers.
It's also HRC's recomended oil for it's 250 gp bikes. I think it's priced about $20 per liter |
I'm off the hook.....
As soon as the Lubemaster gets up and oils his hair, he'll give a 30 word answer to a 300 word problem.
No, I don't sing. Based there for too long. |
Senior Member
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
MAGA
Not an answer to your question, but I use Amsoil mixed 1 little 8 oz bottle to 5 gals of gas in EVERY two stroke I own that requires pre-mixed gas/oil. I have owned/operated/repaired two strokes for a majority of my 39 years. I have been heavily involved in MX racing, snowmobiling and presently experimental aircraft using 2-stroke engines.
I have used many different brands of relatively cheap to relatively expensive 2 stroke oils, both dino and synthetic over the years. When I first got involvecd in 2 stroke powered aircraft, I was using Yamalube R in my Honda race bikes. Another aviator that ran an ultralight business suggested I try Amsoil, as that is all he used with proven results (and the Amsoil was cheaper to boot). For the past 10 years, i have used it exclusively in all my 2 strokes with absolutely zero problems in every two stroke I own (aircraft, MX bikes, chainsaws, weedeaters etc etc). There are plenty of good oils on the market, however, Amsoil is readily available in my locale and is proven and works for ME.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Maybe the ratio of oil to gasoline is different? Plus, I bet water cooled outboards run a lot cooler... In a pinch, I bet you could use either.
At rebuild time, my piston and cyl. were nearly perfect. helps to have a crazy ass 500cc two stroke though, not like you can really wail on that throttle for tooooo long ![]() ![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
As someone with 20 years of mechanical experience rebuilding 2 strokes from my motocross bike, my advice is go to a motorcycle dealer and by a good quality synthetic 2 stroke oil. I am partial to the Castrol. They won't let you down and good quality oil is cheap insurance.
PorschePilot 74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration MID9 Member Beechcraft V-Tail Bonanza (Fly'n high and low) |
In the shop at Pelican
Yamalube is all I ever use in dirt bikes.
MAGA
Good to see I was not the only one who used Yamalube (makes me feel like I made a good choice). At the time (early 90's) someone had told me that some members of Team Honda were secretly using Yamalube R.
When re-ringing my race bikes while using Yamalube pistons showed no carbon and wear rates were low. Making the switch to Amsoil made me nervous at first, but since switching, I have had no issues whats-so-ever and it also burns clean. As I said before, over the years, I have used numerous brands (including Klotz R50, Yamalube R, Golden Spectro, Pennzoil etc etc). Some were good, some were not so good. The Amsoil is good for me due to being readily available, cheap and I mix it the same for EVERY vehicle I burn it in, with absolutely no lubrication failures of any kind over a 10 year period. Many other oils are capable of the same track record. I only offer MY preference due to the track record I have established over ten years of abusing numerous two strokes. My ultralight 440cc "snowmobile" engine runs at 6000-6500 rpm for hours at a time and has about 200 hrs on it. I have changed sparkplugs about 4 times just as preventive maintenance. I have never fouled a plug and my engine compression is excellant. I still keep and beat the hell out of mine and my daughter's motocross bikes, all without any issues. My weedeaters and chain saws start easily have have lots abuse in hot weather over the last ten yrs.
Targa, Panamera Turbo
A dilutable (50:1 nominal) low viscosity that provides lubricity, normally a single weight, no residual (don't want carbon build-up) - must be a clean burning oil.
25 words or less...my work here is done time to take a nap.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
lubricity
I'm gonna use that word at dinner tonight... |
I hope to use it tonight as well...but not at dinner.
Unregistered
There is a big difference between outboard engine oil (PWC's fit in the same category) and motorcycle engine oil.
Personal watercraft and outboards require TWC-III rated oil, it is water soluable, ashless, and works in the lower temps of the water-cooled engines. If you put regular motorcycle oil in an outboard you are asking for stuck pistons. My personal favorite for my waverunners is yamalube but you have to make sure it is the TWC-III version. Last edited by sammyg2; 07-21-2006 at 02:08 PM.. |
Banned
"I love your lubricity." |
Banned
Re: what�s the difference in 2-stroke oil?
If I had to guess, the Suzi has an oil tank and injects it's own oil. That being true, means that part of the engine gets straight oil for lube, and just a bit is squirted in the intact, if any at all. I think all of those use a specified weight of regular engine lubricating oil. By the way, if y'all haven't tried the new Stihl 4 stroke engines on their leaf blowers and some of their weed wackers, you've got a treat in store. They're really nice, quiet, almost no smoke, and very low fuel consumption. And they take oil mix fuel. |
MAGA
I never answered your original question about the marine oil, but what Sammy said above sounds familar and is probably the answer you are lookiing for (outboard marine engines are about the only small engines I have NOT messed with over the years)
Cars & Coffee Killer
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
We use Redline in the shifterkarts. Seems to be much less buildup on the piston and ring than other oils. We mix about 25:1, we even go to 22:1 on really big tracks. We put as much oil in the gas as we can get away with. At that rate we are almost doubling the cost of a gallon of race fuel.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Isn't Lubricity another name for Vegas?
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Thread Tools | |
Rate This Thread | |
