-   -   Dirt Under the Fingernails (http://forums.pelicanparts.com/showthread.php?t=296333)
legion 07-31-2006 06:53 PM
I've been wrenching on my car almost every day the past few weeks. I've developed quite a collection of grease under my fingernails.
I've tried degreaser, Dawn, Gojo, the brush that comes with Gojo, old toothbrushes, tweezers, the hooky thingy on toenail clippers, I've cut my nails very short....nothing effectively gets the grease out. Any tips?
Jared at Pelican Parts 07-31-2006 06:56 PM
latex gloves
legion 07-31-2006 06:57 PM
That's no fun. I need the tactile sensation to effectively work...and the callouses on my fingertips would do me no good. :)
lendaddy 07-31-2006 06:58 PM
Use an old toothbrush and dish soap.
bryanthompson 07-31-2006 07:08 PM
if a toothbrush isn't stiff enough, find a really coarse bath brush and dish soap.
if that doesnt work, there's always a wire wheel attachment for your drill.
legion 07-31-2006 07:10 PM
Heck, why not go straight to the milling bit on my drill press?
charleskieffner 07-31-2006 07:11 PM
put liquid hand cleaner ON FIRST! not alot just enough to give skin a coat. works great. also when you cut yourself REAL GOOD with a dull knife............use super glue to seal your boo-boo!
sammyg2 07-31-2006 07:44 PM
Charles nailed it.
Vaseline under the nails works, so does bar soap rubbed under there but it will drive you crazy. keep the junk from sticking and it will be easy to clean later.
motion 07-31-2006 07:45 PM
Find a hose with really good water pressure. Nail your nails head-on with the stream. They'll clean out in 3 seconds.
Jims5543 07-31-2006 07:50 PM
Go to the beach for the day and play in the sand.....oops! Blomington, never mind.
Soak them in dish detergent (your soaking in it!!) then scrub them while in the shower at the end of the shower.
Don Ro 07-31-2006 07:55 PM
Wash a big load of dishes, pots 'n pans.
Score big w/your wife, too. :)
Motion's idea works for me, too.
slodave 07-31-2006 09:34 PM
I have the same problem at the moment. I wear them as a badge of honor. :)
masraum 07-31-2006 10:17 PM
Yep, the right cleaner and short nails and they should come 98% clean with the rest not really visible.
VINMAN 08-01-2006 05:07 AM
I use either Liquid Glove or NAPA hand protector. I put it on before I work. Make sure I get alot of it under my nails.
I'm another one that hates using latex gloves to work.
My favorite hand cleaner is, Zep TKO. The stuff is awsome.
Way back when, my grandfather used to mix Wisk laundry detergent with sawdust to clean his hands. I remember that always worked great.
onewhippedpuppy 08-01-2006 06:13 AM
My first step is the orange stuff with the grit to it, then dish soap and a coarse brush. Takes care of most of it.
Rot 911 08-01-2006 06:21 AM
I just use the latex gloves unless it is really hot out. Can't stand all that sweat inside the gloves and no evaporation!
sammyg2 08-01-2006 07:23 AM
I can remember about 25 years ago when we used benzene to wash our hands at work. Talk about a good solvent, smelled good too.
I don't recommend it though, it kind of causes cancer.
Tobra 08-01-2006 07:25 AM
In the future get soap or vaseline under your nails to keep it out.
Try scrubbing under there with vegetable oil to loosen it up, then using soap and water
charleskieffner 08-01-2006 07:51 AM
we used tri-chlor @ garrett aviation, motorola used it also by the 55 gallon drum........................it all ended up in the SALT RIVER which meets up with the GILA RIVER. signs posted everywhere downstream...................DO NOT EAT THE FISH!
vash 08-01-2006 09:35 AM
buy a fingernail brush. use it with a gritfree handcleaner. no issues. i wear nitrile gloves 95% of the time now. any and all dirt that gets by, get taken off with my hairwashing. hehe. girlfriends dont let you touch them with nasty hands.
