Cars & Coffee Killer
legion's Avatar
Stripped Brass Screw
The brass screw on the idle control valve on my throttle body is stripped.
I know there is some kind of reverse-threaded drill bit that I can buy to remove the screw after I drill a hole down its center--what is this kind of bit called?
5 liters of VVT fury now
-Chris
Old 07-31-2006, 06:55 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Easy-Out
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 07-31-2006, 07:24 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
One'a these?
http://64.233.187.104/search?q=cache:V2DKaTlL3LIJ:www.sears.com/sr/javasr/product.do%3Fpid%3D00952154000+sears+screw+remover&hl=en&gl=us&ct=clnk&cd=1&client=safari
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-31-2006, 07:28 PM
Don Ro's Avatar
Lightbulb
Left handed drill bit.
Good luck.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 07-31-2006, 07:29 PM
legion's Avatar
Bryan, I've got those....they'll all too big for that screw.
-Chris
Old 07-31-2006, 07:32 PM
Don Ro's Avatar
I also use square shank screw extractors.
They tend to not spread out (causing even more binding) the broken screw as much as regular extractors (EZ out) can as you rotate them.
Good luck II.
Don
Old 07-31-2006, 07:49 PM
Banned
snowman's Avatar
Just drill the largest hole down the center that you can. The rest will almost fall out by itself. We are talking about 4-40 or 6-32 screw sizes here with a brass screw.
Otherwise just drill it out and tap for the next size screw.
Old 07-31-2006, 07:52 PM
B58/732
BlueSkyJaunte's Avatar
Easy-Out (ee-zee-owt) n.
1. The hardest known substance in the universe, most likely to be found snapped off in holes that have been inexplicably drilled into bolts, screws, etc.
ΜΟΛΩΝ ΛΑΒΕ
Old 07-31-2006, 08:12 PM
Many times a left handed drill bit is all you'll need. The bit will drill out the offending bolt, but I've found that it also tends to back the screw out as you're drilling. We've got a couple of 1/8" drill bits in the shop we use for exactly that purpose, and they work great.
Good luck,
Jim
Old 07-31-2006, 09:49 PM
Banned
snowman's Avatar
For the real problems theres wire EDM.
Old 07-31-2006, 09:51 PM
Mike Bonkalski's Avatar
Cut a slot with a dremel and use a flat-blade screwdriver.
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 08-01-2006, 06:30 AM
legion's Avatar
I have done that before, but I can't here. The screw is set down in a hole about 1/4".
-Chris
Old 08-01-2006, 06:39 AM
legion's Avatar
I got a hold of a reverse-threaded tapered bit. Worked like a charm!
-Chris
Old 08-01-2006, 08:09 PM
You do not have permissi
john70t's Avatar
Bar soap for wood, antiseize for metal. Dremel should sell a 90deg drive head or tool for those situations.
Old 08-01-2006, 08:15 PM
