Bryan,
I'm in the planning stages for a fence myself. And yes it's because we just got a dog, as well. ![]() ![]() Did a quick spreadsheet the other day and found that the prefab sections will save me about $50 for the 80ft section that I need to replace. ($500 for build it myself, $450 for pre-built.) I'm not sure that the quality of the prebuilt panels will be as good as DIY, but the labor savings might make up for it. I certainly don't want to spend the next several weekends pounding nails into fenceposts. Let us know what you decide, and post pictures. For inspiration, if nothing else. ![]() Good luck. Jim |
If your going to make it yourself I wouldn't pound nails. Take the time to predrill holes in the fence pickets and use galvanized screws they hold much better. I have a 10 year old premade fence and I constantly have to hammer in the staples that were used. As the sun and rain work on the fence along with wind there is a fair amount of movement.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
![]() I've built a fence myself in my 1st house and I'll echo what everone else said. Good level, power auger, Quickcrete and stainless steel screws or nails. Good luck!
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
I built a 142' fence last year, I considered the pre-made sections but they seemed flimsy. As others mentioned... thin wood, staples etc.
My brother put up a fence this spring, and bought those prefab panels despite my advice to the contrary. He is on very rocky ground, and was not able to space the posts evenly. He spend days and days trying to get the holes dug, but in the end gave up and ended up having to cut panels short.. many of them in half. Looks sloppy. So, dig a few test holes before you go with pre-fab sections. If you are on rocky terrain, don't expect to be able to space them evenly. FWIW, I didn't use concrete on my fence , I used compacted 1/4" gravel with 3/4 at the bottom of the holes for drainage. Holes were 4' deep. Reason: frost heave. If your set in concrete, if the fence shifts you ARE NOT going to be able to straighten it. My neighbor learned that the hard way, and suggested I use the fine gravel. It is very solid, and I can dig it up if I need to. Frost may no be an issue where you are.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Thread Tools | |
Rate This Thread | |
