Greasy Member
many944s's Avatar
Help... Tig welding magnesium
Hey all, have tig welded quite a bit in the past, but have come upon a situation that requires me to weld a cast magnesium housing...
Any suggestions?
I know enough now, that I have to track down some magnesium filler rod. Anybody had a piece of cast magnesium burn up while welding (would rather not have that happen). Is an oven required to heat the entire piece before welding?
Also, should I use a particular setting for penetration or pulse frequency?
TIA,
Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 01-18-2007, 05:56 PM
Banned
fastpat's Avatar
Re: Help... Tig welding magnesium
Any suggestions?
TIA,
Nick
I don't know much about welding, but since Mg can sustain its own fire at 3000F, I'd say that it's a job for absolute pros.
Old 01-18-2007, 06:17 PM
the key to it is to keep the tungsten as close or submerged in the weld pool this will prevent cracking. Use the better mag rod.. don;t have the number in front of me but its something like 150 bucks for a 5 lb box.. it will not start on fire unless you get it really hot.. Just be careful the zinc gases are not to frinedly to us humans.. .. I really don't know how much experience you have with tig welding but this should not be taken lightly
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-21-2007, 07:34 PM
If your good at welding aluminum, Magnesium should give you no problems. From a welding aspect, the two act/react very similar.
Straight Argon is the preferred gas. Crank your postflow up as much as possible. If you can, weld in an argon environment, since magnesium burns in air. AC and High freq on the welder.
If your dealing with a casting, the base metal is likely one of
AZ63A, AZ92A, AZ91C or AM100. If so, the filler you need is AZ92A.
Be careful how you dispose of any filings or small scraps of material (if your doing any cutting or grinding)
Vin
Old 01-22-2007, 06:01 AM
Greasy Member
many944s's Avatar
That is just the info I was looking for!
Granted, I was a little worried about the burning aspect as this is a 1970's hewland LG500 casting! Try finding one of those at a reasonable price anymore
I have tracked down the AZ92A filler, so I think I will be cranking up the lincoln this weekend.
Thanks guys!
Nick
Old 01-22-2007, 05:28 PM
DUK DUK is offline
DUK's Avatar
Nick, PLEASE have a bucket or two of sand nearby. I've welded several pieces of mag and never had it flame up, but had a good friend lose everything from a mag fire. Also it really likes preheat, I just use a rosebud and make sure to not hit the edges. That's where it likes to catch fire. If it's an old rearend housing or trans. use plenty of mineral spirits or brake clean. And as stated before it's best to do it outside for ventilation.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 01-22-2007, 06:32 PM
