BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
HELP! Brake job....
HELP!
Doing a routine brake job on the Tauras today...well, didn't go very routinely! For starters on the Front right one of the caliper slider bolt's was missing and the caliper mount bolts were loose! Thankfully the right side was all nice and tidy.
Here's my problem, turns out the shop that did the brake job before strip one on the caliper mounts. I get the top bolt in, but the bottom thread is all messed up. I have a tap and die set, but no idea how to use it. Any machinist type guys know of a website I can go to so I can learn how to use this thing or want to come over and help?
And I haven't even gotten to the rears...
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 12-18-2007, 02:34 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
You may be better off buying a new caliper.
I don't know where you can get oversize pins?
Prolly around $80 or so...
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 12-18-2007, 02:39 PM
BRPORSCHE's Avatar
Yeah maybe buying a unloaded caliper for that side might be my best bet.
-Tom
aka "Wolf boy"
Old 12-18-2007, 02:43 PM
Are the threads totally FUBAR? You may just have to a light tap.
Warren & Ron, may you rest in Peace.
Old 12-18-2007, 02:45 PM
dhoward's Avatar
Caliper should come complete.
Just add pads and brake fluid. Take your time and use some PB Blaster on the brake line fitting. Use a flare nut wrench.
Good luck!
Dan
1969 911T (sold)
2008 FXDL
Old 12-18-2007, 02:47 PM
BRPORSCHE's Avatar
Whoops, is the caliper mount included with the caliper? And Rick, the first three threads are totally messed up. When trying to get the bolt in, it wants to go in at a weird angle.
-Tom
aka "Wolf boy"
Old 12-18-2007, 02:50 PM
BRPORSCHE's Avatar
This is the caliper mount I need.
-Tom
aka "Wolf boy"
Old 12-18-2007, 03:09 PM
So it's crossthreaded.
You may be able to correct by:
" 4. Secure the workpiece firmly.
5. Apply an appropriate lubricant.
6. If the tap set has a separate handle or rod, insert it.
7. Hold the tap in line with the hole and turn it clockwise. You may feel the material breaking.
8. Every few turns, back the tap out (counterclockwise/anticlockwise) to clear away chips of loose material. This is especially important in a blind hole, one that does not go all the way through the workpiece.
9. When the tap has reached the required depth, back it out, clean out chips and any cutting fluid or lubricant, and try your screw or bolt in it."
Old 12-18-2007, 03:15 PM
BRPORSCHE's Avatar
Thanks Rick!
P.s. Any snow on the ground? Going to be in Sussex county this coming Sunday. Better be snow christmas day....
-Tom
aka "Wolf boy"
Old 12-18-2007, 03:21 PM
Pretty much a 4 inch thick layer of ice right now. However, there is likely more snow in Sussex (not far from me). The light reflection off the ice, on the lawns, does look nice at night though.
Old 12-18-2007, 03:30 PM
