Television Wall Mount Options
So I finally bought a new TV. My wife and I want to put it on a wall mount that pulls out from the wall and can swing right to left so that we can put the TV in the corner of the room. After picking up the TV I went to Sears and the only wall mount that I found cost $300.00! I figured before I spend $300 on a mount I would ask you guys if you know of any mounts that are decent quality and hopefully don't cost so much. I checked ebay but I hate to buy stuff off of ebay. Anybody have a TV wall mount that they would recommend?
The TV is a 40" Sony Bravia
Thanks,
Shawn
Old 02-01-2008, 07:18 PM
The mounts for these things just seem to be expensive. I suspect because they are heavy and having them able to support the TV with the arm extended and also stable when articulated requires sturdy thought out construction.
Think about it this way. You've got an expensive item hanging at the end of a rod. Would you rather pay $300 for one that's really sturdy, or $100 for one that's questionable.
Old 02-01-2008, 07:32 PM
I didn't blindly buy a cheap mount from ebay for the reasons that you pointed out. I just thought maybe someone had bought a mount that they were pleased with for less than $300 or had bought one for $300 that they were really happy with?
Old 02-01-2008, 07:59 PM
Senior Member
Have you tried Home Depot or Lowes? Picked up my last wall mount there and it was a lot less than $300 and was still professional.
Old 02-01-2008, 08:19 PM
WI wide body's Avatar
If your TV is a flat screen it's really not that difficult to make a recess in the wall for installing and it really looks good.
The only thing that I thought about was what's gonna happen when the next latest and greatest thing in TV's comes along and it won't fit in the current recess!
Old 02-01-2008, 09:02 PM
I had to buy the most expensive one they had at Best Buy because I wanted it to be able to both tilt and swing left/right. About $250. I will say it is quite robust!!!
1972 911T/S MFI Survivor
Old 02-01-2008, 09:23 PM
Free minder
Aurel's Avatar
Have you checked this website?
http://www.mountsdirect.com
Aurel
Old 02-01-2008, 09:28 PM
Unfortunately the TV is going in the corner of the room so recessing it in the wall is not an option (my wife won't let me put it over the fireplace).
Thanks for all the tips everybody I am sure I will find something that will work through one of the recommendations.
Old 02-01-2008, 09:58 PM
AutoBahned
RWebb's Avatar
you might also try a sheet metal shop
Old 02-01-2008, 10:34 PM
I just saw two models from Costco. It comes with shelves and you can mount your TV 3 ways.
Hard to explain until you see the units.
BTW, my Bravia lasted 6 months. Hopefully, you won't have any issues with yours.
Bought a Panasonic plasma to replace the Sony.
Old 02-01-2008, 10:59 PM
I thought about just making a mount but I already have enough projects going to keep me busy for a while.
I am thinking about checking out this one from the link Aurel posted:
HTML Code:
http://www.mountsdirect.com/product_info.php?products_id=725
The above was an attempt at posting a link....I said attempt
Old 02-01-2008, 11:43 PM
Thanks for the Costco tip I'll check it out. I hope this TV lasts longer than six months but I guess if it breaks at least I can reuse the mount which will probably end up costing about the same as the TV
Old 02-01-2008, 11:47 PM
Shawn,
Do not go to the TV section. Go to the furniture section. IMO, the 2 new units are a bargain and cost, I think, almost as much as a 'stand alone' mounting bracket. I have a 50" plasma and have been thinking about buying the 'furniture unit.'
Old 02-02-2008, 12:16 AM
