bigchillcar's Avatar
restored laptop to original configuration..problems..
it's a dell inspiron 9300. first thing i did was organize data folders with family pics, documents, etc. that i didn't wanna lose and cut to a portable hard drive. then i forgot until it was too late, after doing a F11 command and making it restore itself to the original point when i bought it (remanufactured)..prompting me for country, language, time-zone, etc. in doing so, i lost all of my installed programs that i did myself, as well as forgetting to move about 500 songs i'd downloaded over two years...ouch! don't guess there's anything i can do about losing them as well as all my bookmarks..forgot to save that file as well (it was the middle of thenight and i should have left it well enough alone).
other problem is that my dvd+rw drive won't play. it lights up, makes sounds here and there, but never gets to spinning up. right-clicking the drive and checking the device, it says it's working properly. the laptop did suffer a little fall a few months back..could it have just loosened a cable inside? if so, is the drive easily removed or is time for the 'geek squad'? i've taken apart and re-worked a few desktops in my day, but never messed inside of a laptop. any advice?
thanks!
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-21-2008, 10:23 AM
holy cow...windows media player just did 'do you want to look for more music files' question during new configuration and found my 580 songs! well, that part's a huge relief!
Old 02-21-2008, 10:38 AM
spoke too soon.. only found some, maybe 50. i think most of it was in the 'shared folder' under doc's and settings that was cleared out when i forgot to move those files to the portable drive during the reset. crud..
Old 02-21-2008, 10:41 AM
The Unsettler
stomachmonkey's Avatar
is the dvd a dual cd/dvd device?
they have 2 lasers, one for cd, one for dvd. sometimes one laser fails and not the other, try various media
"I want my two dollars"
"Brandon Won"
Old 02-21-2008, 10:51 AM
thanks. yes, it will operate both. just checked..it will play a dvd, but won't recognize a blank or installation cd...
Old 02-21-2008, 11:36 AM
slodave's Avatar
There usually is only one laser that adjusts its height and intensity. Having taken many apart for the laser and rotor, I have never found two.
Old 02-21-2008, 12:07 PM
Senior Member
Check the recycle bin, might be some files in there that you want to restore.
Old 02-21-2008, 12:13 PM
The Unsettler
Just fixed a PC for a friend and the problem was dual lasers. CD worked, DVD was dead.
Don't remember the specific model number/manufacturer.
"Brandon Won"
Old 02-21-2008, 12:19 PM
slodave's Avatar
But did you actually tear down the drive? I have two in front of me and they are both one laser.
Old 02-21-2008, 12:25 PM
The Unsettler
No, I did a search for known problems with the particular brand and model and it was the first of many threads that showed up.
Just because you have not seen one yet does not mean it is not true.
"Brandon Won"
Old 02-21-2008, 12:34 PM
slodave's Avatar
I'm not saying they don't exist, but dual laser drives are rare and usually old. It's less expensive to use one laser that changes intensity and moves in order to read/write. I have dismantled around 100 over the years for the parts and have not come across a dual laser unit. Regardless on single/dual, the drives are sensitive. The laser unit floats and even readers adjust the distance of the laser from the media. If you drop or jar an optical drive, there is a chance you will not the laser unit out of whack.
You can take a laser out of an optical drive and in about half an hour, create a little laser pointer that will actually cause a match to combust or pop balloons
Old 02-21-2008, 01:01 PM
craigster59's Avatar
So if you spend a couple hours on it, can you build a "death ray"
Old 02-21-2008, 01:14 PM
none, joe..setting the system back to original configuration wiped a lot out.
Old 02-21-2008, 01:33 PM
it's a sony dvd+rw DW-Q58A......?
Old 02-21-2008, 01:35 PM
slodave's Avatar
Every now and then, a low level driver in Windows corrupts and you have to go into the registry remove the entry and reboot. Windows will rebuild the registry key and your drive may work.
Old 02-21-2008, 01:40 PM
slodave's Avatar
These are the two registry keys you need to find and remove.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}\LowerFilters
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}\UpperFilters
Old 02-21-2008, 01:46 PM
gettin' on this like flies on *****.. will report shortly..
Old 02-21-2008, 01:58 PM
found the registry keys, but not where it says \lower filters or upper filters?
Old 02-21-2008, 02:31 PM
nope, found a line that says lower filters, but not higher....should i go ahead and delete the lower filters line?
Old 02-21-2008, 02:34 PM
slodave's Avatar
Here's a screen shot:
If the upperfilters line does not exist, don't delete it
Delete the lowerfilters, close regedit, reboot and see what happens.
Old 02-21-2008, 02:36 PM
