Solar-powered spotlights
Anybody out there use solar-powered spotlights to light up trees (or something else) on their lawn?
We had a ton of tall bushes put in our back yard last fall (to block out a b!tch neighbor), and we'd like to light them up at night so we can see them from our sunroom. The solar-powered accent lights that are along paths seem so weak. I was wondering if anybody could recommend a worthwhile set. I don't mind spending a few bucks; I'm not looking for the Home Depot specials. Thanks.
'08 RX350 (Hers) '84 911 Carrera '83 911SC Cabrio '06 Miata |
Senior Member
I tried several of them and they were so dim that I replaced them with powered versions. Assume that if you buy an industrial version that it might be better but have not tried them.
Just found some solar panels that put out 45w on CraigsList and going to try to play with these a bit. Want to rig these up to my backyard lighting to kinda get my feet wet in the solar field and slowly try to get off of the grid if possible. I use enough power that it would be difficult to do totally but with all the sun that we get in AZ might as well try to do what I can.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
The Unsettler
Yeah, what Joe said.
They only give off a soft glow.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
If they are anthing like the accent lights I have in my dog run, they are effing worthless, and we get a lot of sun here in Colorado.
These are the ones I see all the time that don't do much:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100026060&N=10000003+90401 I was hoping that someone had tried something more like this: http://www.solarilluminations.com/acatalog/Solar_Spot_Lights.html
Parrothead member
I bought two to light up my flag pole. They were pretty bright, but the problem was they only lasted about 6 hours.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Monkey with a mouse
Check these out:
http://www.gardeners.com/Powerful+Solar+Spotlight/35-070,default,pd.html IMO, you need a large, separate solar panel like the above offers to gather enough "power" for the LEDs - and more than one LED! These claim to output 90 lux at four feet. FWIW. Best, Kurt |
