abit off center
cgarr's Avatar
Heating and Cooling Guys?
Been out of the Cheating and Fooling business too long, have to replace the furnace since the exchanger is starting to crack. What decent high efficiency brands are out there, Looking for 80 to 100K BTU or which ones do you stay away from. This is going in Michigan so it used 6 months out of the year.
______________________
Craig
G2Performance
Old 01-03-2009, 12:16 PM
Navin Johnson
TimT's Avatar
What type of heat? Hot Air? Water? Steam?
I just installed a new boiler myself this year, replacing the original boiler (90+ year old) which was of unknown efficiency. I elected to steam with steam, as the cost to repipe would have been way to high, even though I do the work myself.
I ended up installing a Weil-Mclain SGO-4 with Beckett flame retention burner.This is an 85% efficient steam boiler.
If you have hydronic hot water you can get furnaces that are almost 100% efficient. The new units are tiny!!
I found a good heating help web site. http://www.heatinghelp.com Its a mix of pros and DIY people like me. The guys there were very helpful.
'69 911 GT-5
'75 914 GT-3
and others
Old 01-03-2009, 12:35 PM
abit off center
cgarr's Avatar
Its a forced air Natural Gas
Craig
G2Performance
Old 01-03-2009, 12:39 PM
least common denominator
scottmandue's Avatar
Uh, you know this is a fix ASAP thing right?
As in life and death importance.
When I was in the biz Carrier was top of the line.
Last time I checked the super high efficiency heaters needed a condensate drain for the heater.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 01-03-2009, 02:36 PM
Canadian Member
911Rob's Avatar
I use "American Standard" up here in Canada; they run about 9 months of the year here.
No challenges to date and price is very competitive.
LINK HERE
Hope that helps?
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 01-03-2009, 03:14 PM
ruf-porsche's Avatar
Nothing run like a TRANE
Old 01-03-2009, 03:19 PM
Bought a Lennox XP21. Heat pump and matching air handler. Perfect for our moderate climate.
It has auxillary heat option for either gas or electric.
It has saved me 50 bucks a month this winter and 75 during the summer.
House is dryer, quieter and cooler/warmer.
High efficency might cost a bit more at the front end but I save a good bit of money each month. I unit that was a few grand less would not have saved any money.
Old 01-04-2009, 06:44 AM
UnRegistered User
billybek's Avatar
American Standard once owned Trane, and the furnaces are pretty much identical.
I have a 10 year old Trane high efficiency that I have not had any trouble with.
I really like the York Diamond 90 furnaces too. They look very solid and have a good reputation.
It is really hard to compare them unless you have access to some recent installs.
Some are noisier than others.
When I installed mine I used canvas connectors to reduce vibration and noise as direct drive fans are much louder than the old belt drives. I would also consider now the variable speed blower motor, much more efficient...
Bill K.
Old 01-04-2009, 07:27 AM
JeffO's Avatar
I converted from electric to natural gas with a weil-mclain three zone. Two zones are baseboard and the upsatairs is hot air. Love it for its small size and super effiency.
http://www.weil-mclain.com/products/display/1-Ultra%20gas?show=features
"The smaller the fine print, the larger the risk."
1988 911 coupe
2008 VW R32
2004 530I
Old 01-04-2009, 08:32 AM
Retired Member
Brian 162's Avatar
Carrier, Bryant, Payne are identical and made from the same manufacturer. Easy to get parts for.
Lennox is a good product however some of their parts you have to go to Lennox and they won't sell parts over the shelf.
Keeprite, Heill, ICP are again the same furnace made by the same manufacturer.
Trane is good as well.
Any of the above makes have a good name throughout the industry and they all stand behind their product.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 01-04-2009, 03:44 PM
Heil forced air gas furnace. Condensation burner. 95% efficient. Installed last July. So far so good.
87 blk coupe
Old 01-04-2009, 06:49 PM
