Born to Lose, Live to Win
zipper problem/question
got a problem with the zipper on this brief case...when i slide the zipper, as if to zip it.....the zipper does not zip.... this means its broken i presume?
if i twist the part you grab with your hand at an angle and try to zip, i can get it to zip a little but not really.... does this look like a candidate for installation of a new zipper? I think I paid about $300 for this damn brief case a while ago and now its rendered useless... it looks like a heck of a job for a pro (expensive) to replace this zipper and i hate to spend $100 having it fixed. anyone need a brief case? Bill Amberg of London...cheap ![]()
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
Banned
Shoot 'em an email--I'd be they'd fix it for ya for free.
http://www.billamberg.com/pages/contact/contact.asp |
thanks. thought about that, but im assuming i would have to ship it to england...i want to keep this inexpensive..
Your in new york. You probably have 8000 places to have it fixed within a four block radius.
Ryan 79 930..... among other fine German cars.
im not in NYC anymore. if i was, i would know just where to go....im up in the boonies now
i guess im wondering, does this look like an expensive job? i have no experience with zippers...but it looks involved..looks like it was sewn with a machine prior to completion. not sure what it would entail now a search reveals one zipper repair place in my city...i guess ill take it there
So did you pack in the law job then?
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx |
no no. i moved out of NYC at the end of 2003 and found a job up here. not sure why i did such a dumb thing, but i did
"O Gruppe 13"
...what you want for it?
G-Man 89 964 C4 86 930 |
let me see if i can figure out what it costs to fix it...then ill tell ya. it wont be much. compared to what i paid for it...ill report back in a few days
Detached Member
I had a new zipper put in my favorite leather jacket a few years ago. The tailor charged my something like $50. Come to think of it, go to an upholstery shop.
Hugh |
I don't see any physical damage like broken or missing teeth that would prevent the zipper teeth from fully engaging. Have you tried rubbing a little candle wax along both sides of the area having the problem? It helps lubricate the zipper.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Double Trouble
Why did I automatically think " Beans & Frank"?
no i didnt. the whole zipper is having a problem...seems to be a problem with the zipper pull not pulling both sides tightly together. i tried some oil last night. made no difference. ill try wax
thanks
What generally happens is the outside edges of the zipper teeth get worn very slightly and so does the inside of the slide portion of the zipper and eventually one day there is not enough pressing together of the teeth so they latch. You could try squeezing the slider at it narrow end just slightly so the teeth are pulled a bit more tightly together and do it on the outside and inside portions. Not much is needed and it is easy to crush it so care is needed. To replace the zipper on a case like that I imagine nearly the whole thing will require dissassembly as the zipper is sewn in with it laying flat.
as for it wearing out...geez, i probably only zipped 50 times since i owned it, if that hmmm what to do
try holding tension on the pull tab and then alternate sides and pull each side of the zipper one notch at a time through the slider until you're all the way to the end. fixed a lot of zippers that way.
shoe repair/ luggage repair place can fix that up in a jiffy.
poof! gone |
that a manbag?
poof! gone |
![]() angela p.s. John - the engine in Butters is still running GREAT! Thanks!
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
