vash's Avatar
BBQs galore is expensive to begin with.
poof! gone
Old 02-06-2009, 10:02 AM
No Band
futuresoptions's Avatar
Am I missing something?, Just blast the rest of the porcelain off, put bacon grease over all of it and put them back in the cooker for about half an hour on high heat.... just hit them with a wire brush prior to each use... Or use aluminum foil over them each use... and last but not least.... take them out, put in some support rods (Rebar if thats all you have) and buy a single piece of stainless steel expanded metal to put over the support rods as your new grill surface... Back in the day our grill was cinder blocks and a shelf out of an old fridge.....
He was a helluva plumber and his outfit was self explanatory
Old 02-06-2009, 11:11 AM
austin552's Avatar
Originally Posted by tabs View Post
FK em all with their snobbery of low and slow over wood. If ya like your gas grill then by all means use it.
No Pelican badge for your grill.
1974 911s
Old 02-06-2009, 02:15 PM
Registered abUser
TerryH's Avatar
Originally Posted by PorscheGAL View Post
Alton Brown on Food network suggests you put the grates in the oven on self clean. Try it. It can't hurt.
I did just that today and must say it works great or is it grate? I've always wire brushed the tops, but the underside needed scraping with a putty knife. Two SS grates that just fit in our 24" wall oven. Three hours later they came out with just white ash. Wire brushed them and then washed with SOS pad to get a little shine back. While I was at it, I scraped out the whole bbq and even changed the drip pan.
Almost hated to get them dirty again. Thanks for the tip!
'81 911SC Coupe SOLD
Old 02-14-2009, 08:45 PM
