Banned
Opposing piston engine
http://engineeringtv.com/blogs/etv/archive/2008/07/01/opposed-piston-opposed-cylinder-engine.aspx
Very cool. New type of piston engine. |
The CEO said 40% efficiency? Is that gonna work in the long run? The second chap said 3 HP per cu. foot? I hope he meant per cu in.
gotta love the first question from the reporter after a rather technical description:
"sooo you have one cylinder for two pistons, right?"
Silver '88 RoW Carrera Grey '06 A4 Avant |
In the shop at Pelican
Junkers tried this with a 2 stroke diesel engine in the 40's
canna change law physics
My former company has 2 compressor designs which has horizontal opposed cylinders, to reduce the force couple. It used a 3 rod design, of which 2 were split. They were considering going to a 4 rod, double split design, so that more of the parts would be common.
The real savings is in the foundation for a compressor, since you don't have to deal with that force couple from the offset crank. It would also help in a car engine, with the reduction in weight of the block and in the less vibration transmitted to the frame. I'm not sure why they think the design would be 40% thermally efficient.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Looks like a cool idea if they can keep it funded and get it more maistream. Add some fins to that baby and make an aircooled Diesel!
abit off center
I still don't like engines whos parts have to stop and change directions.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I believe Fairbanks-Morse had an opposed piston, two cycle diesel locomotive engine back in the '50's.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Navin Johnson
Like a two stroke or a four stoke engine where the pistons instantaneously change direction? The piston reaches apogee, then changes direction at some point the pistons motion did stop... even if for micro seconds.. Flywheels and multiple cylinders smooth things out..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 03-13-2009 at 06:36 PM.. |
Navin Johnson
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
AutoBahned
"extremely lightweight"
yes! |
abit off center
This is the one I like::
The Puff.
'70 CT1B '11 GTS 300 Super |
Banned
Dog-faced pony soldier
Internal combustion engine efficiency is WAY less than 40% today.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
The RX-7 fanbois call them "boingers". For pure simplicity, adaptability, and power per pound, you don't get more better than a rotary turbo. Want more power? Add a rotor. Or...go newfangled: http://auto.howstuffworks.com/quasiturbine.htm
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Unregistered
I wonder how they are going to deal with the unburned fuel and cylinder lube in the exhaust, which is why the 2 stroke died in the first place?
HP per pound, it is hard to beat a turbine. Making a turbine work well in a car is another matter.
But then again, on a thurst per lb of weight basis, it's hard to beat a ram jet!
AutoBahned
Air Medal or two
At least they tried
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
